Thread: Random brake failure
Results 1 to 5 of 5
  1. #1 Random brake failure
    Apr 2011
    NC
    Hey everyone,
    Got a friend who called with a problem with his 2004 Pontiac GP 6 banger(no SC). When he goes to slow down at a light or turn, the brakes get hard and go to the floor. He hears a "Motor" running when this happens. I asked if he felt pulsating in the brake pedal and he does not. There is no ABS light on either. Any ideas? I am thinking maybe a wheel sensor but not sure.
  2. #2 Re: Random brake failure
    could be the abs pump or master cylinder has gone bad, check the brake fluid level, if its low look for leaks at the brake calipers or behind/under the master cylinder its self.
  3. #3 Re: Random brake failure
    Ohio
    i have this same problem slightly. i slow the car down and it gets to about 10 mph and you hear a groaning sound but the pedal doesnt drop completely. it dont happen all the time so im pretty sure its the abs pump. and my brake fluid is full by the way
  4. #4 Re: Random brake failure
    St. Louis
    With the brakes getting hard sometimes it almost sounds like the booster is bad. Usually when the MC lets go the pedal will go to the floor and might build pressure if you pump it a few times.
    And yea, the ABS pump is probably freaking out, hence why it is running a lot. IIRC shops can run a test on the ABS parts of these cars. May be worth the $80 diag. fee to find out before he slams into someone.
  5. #5 Re: Random brake failure
    Apr 2011
    NC
    He has checked for leaks everywhere. MC is dry all around it. Fluid is full. All brakes lines are dry and front caliber brackets are tight. I though maybe a booster but this is a random occurence. I think he is going to bring it in to get it scanned. Thanks for the replies everyone..
  1. jpg. failure
    By hodge in forum Forum Bugs/Suggestions
    Last Post: 04-04-2011, 08:11 PM
  2. Failure
    By mechguy in forum Off Topic Discussion
    Last Post: 03-25-2011, 01:39 AM
  3. random brake rubbing under 20mph
    By Lord4play in forum Brakes/Suspension/Chassis
    Last Post: 12-01-2010, 04:10 AM
  4. Random brake pedal grinding
    By ptnothere in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2010, 12:25 AM
  5. possible failure yet again??
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2008, 08:40 PM
