Thread: parking brake "ticking noise"
Results 1 to 5 of 5
  1. #1 parking brake "ticking noise"
    Iowa
    here's the story. the brake light on my dash was on so i checked the brake fluid level and found it to be low. i then added fluid to see if the light would go out (which it did) but now there is a loud ticking noise coming from right next to the parking break pedal that only stops if i engage the p-brake. any suggestions on how to fix this?
  2. #2 Re: parking brake "ticking noise"
    Iowa
    also, the noise only happens if the car is running. if i turn the ignition to "on", it will make the noise for about 40-50 seconds then stop. but if the car is running it is constant.
  3. #3 Re: parking brake "ticking noise"
    Iowa
    not sure why, but having the DRL fuse pulled out was causing the problem. anyone else have this happen with the DRL fuse removed?
  4. #4 Re: parking brake "ticking noise"
    Iowa
  5. #5 Re: parking brake "ticking noise"
    Donating Users crock's Avatar
    Traverse City, Michigan
    My 00 did this. The parking brake is just getting stuck in. Normally itll unstick itself. If yours is still doing it while driving? idk
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. Steel brake hose "guide"
    By MBruneaux in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2010, 07:26 AM
  3. "CLUNK" suspension noise when i step on it?
    By whitelightning in forum General Tech Discussion
    Last Post: 05-29-2010, 05:51 PM
