Thread: P.S. Rack and pinion? PLEASE HELP!!
Results 1 to 5 of 5
  1. #1 P.S. Rack and pinion? PLEASE HELP!!
    Cicero
    Hey guys can you explain some of the symptoms of a bad rack and pinion in a 2000 grand prix se. 3.1 motor.
    My car about 5% of the time turns hard to the left. its gat 2 brand new quick struts in front, 2 new outer tie rods, new drivers side horizontal lower control arm bushing. it made it 95% better b ut still does it a little. My p.s. PUMP IS USED and the fluid in the resevoir dosent smell right and when i open it, it seems to have some air in it, im not sure if that is normal. PLEASE HELP!!
  2. #2 Re: P.S. Rack and pinion? PLEASE HELP!!
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    The fluid should not have bubbles in it, but the steering pump knows no direction, so if you only have a problem turning one direction there's a good chance it's your steering gear. Sounds like the pump might be bad too.
  3. #3 Re: P.S. Rack and pinion? PLEASE HELP!!
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Did you get an alignment after you did all that work? If not....thats probably it
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  4. #4 Re: P.S. Rack and pinion? PLEASE HELP!!
    Cicero
    i didnt get an alighnment but my car still drives strait with the wheel strait.
  5. #5 Re: P.S. Rack and pinion? PLEASE HELP!!
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    On my 2000 GP GT it felt like i was all on my own with the steering which was due to the pump and then i had to get the rack and pinion replaced too. It was just overall hard to make a turn and i felt like i was goin to take out someone.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  1. 04+ Rack and Pinion replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2017, 01:31 PM
  2. rack and pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 02-21-2011, 09:53 AM
  3. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
  4. Rack and Pinion Sweating??
    By jpom in forum General Tech Discussion
    Last Post: 08-26-2009, 11:19 PM
