Thread: ABS Trac Off light on
Results 1 to 3 of 3
  1. #1 ABS Trac Off light on
    Indiana
    I have a 1999 Pontiac Grand Prix GTP. For the past few weeks my ABS and Trac Off lights have been on. I've done some research and most of it points to the ABS module. The only difference from everything I've found online is that, when my lights are off, it's much more difficult to stop, I hear the grinding noise, and I have to begin slowing down a lot sooner. But when the lights are on (they usually come on after driving just a few minutes and usually stay on the entire trip) I have no problems stopping and don't hear any unusual sounds. I was planning on selling this car soon, and don't want to spend the $900 the local dealership quoted me (without seeing my car) so if anyone could point me in the right direction for what I should check and attempt to replace myself, I would greatly appreciate it.
    I had my brakes and rotors (front) and one hub replaced a few months back.
  2. #2 Re: ABS Trac Off light on
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    i had a similar issue not too long after i bougth my 02 gt. ended up being that the wire from the hub to the engine bay had corroded and lost continuity on the front drivers side. there is also the same wire on the passengers side. i had the local junkyard cut this wire out of a junker and spliced it into the harness then insulated the f*** out of it. i havent had an issue with it since (over a year ago)
  3. #3 Re: ABS Trac Off light on
    Donating Users NoBoost91's Avatar
    Queens, New York
    Yea same issue I had when the lights were off the car just didn't wanna stop , abs would kick in way too much , I would put my money on wheel hubs , jack the car up and put Your hands on opposite sides of the tire to see if there's any play
  1. 03GTP Trac off and ABS light
    By 2003GPGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2011, 11:31 AM
  2. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  3. abs and trac light on
    By 99silvergtp in forum Off Topic Discussion
    Last Post: 01-07-2010, 07:32 AM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. my low trac is lit and so is the abs light
    By beast55 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:23 PM
