Thread: Rear shock mount problems
Results 1 to 4 of 4
  1. #1 Rear shock mount problems
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    Not sure where to post this but anyhow, my rear shock towers are rotted out and pushed in making my car lower and rubbing, this is my first gp with this issue, but i hear its very common, is there any write ups on how to fix this, or and good tips?
    i need to fix it this weekend but have honestly no freaking clue what to do.
    thanks
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  2. #2 Re: Rear shock mount problems
    St. Louis
    Grab some steel and weld it in would be my only guess. Either that or find a car w/ good mounts and cut them and patch them into your ride. I assume the rear mounts are similar to the mounts in the front, never looked at the rears before though.
  3. #3 Re: Rear shock mount problems
    you and the lounge...
    post in the technical sections if you want to talk about your car. the lounge is basically 'off topic' that is SFW. moved.
  4. #4 Re: Rear shock mount problems
    FLINT/michigan
    thats why i said im not sure where to post, and then i wait for you
  1. Does anyone know where to get a rear shock tower panel?
    By topswap in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2011, 03:00 PM
  2. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
  3. Rear-mount turbo?
    By 01gtspecial in forum General Tech Discussion
    Last Post: 11-08-2009, 06:09 PM
