My 00' Regal is in need of strut mounts I think. I put new (all the around) Spring Tech struts. When you open the hood, I can press on the bumper, up and down, and watch the plate that lays against the upper mount move almost a 1/4". The retaining nut is as tight as humanly possible. When I go over a bump I can hear a sound. I know my ball joints are due to be replaced, but I dont think that the strut, or should I say I KNOW the strut is not all the way against the mount (rubber). The drivers side is way worse that the pass side. The rears are fine. Do I need strut mounts?? If not, why does the top of the strut have so much up and down play?? Is the strut out of spec? Is there a spacer that will cure this? I cant get it any tighter. Used neumatics, and a 50' pipe for leverage!!Lol.
Thanks for the input,
Kevin
