I just bought a 2004 GTP Comp G for the wife, when i bought it it had weak brakes and a leak from the passenger front caliper, I purchased a reman caliper, installed it, bled it (i have done quite a few brake jobs before) and now i have no leak, but the pedal still goes slowly to the floor, so i bled it some more (all 4 wheels), still the same, so i figured the master cylinder, replaced that, bench bled it, then bled it one the car starting at the back, still has the pedal slowly going to the floor, almost like air in the line.
On the front drivers side when it is bled, the fluid comes out forcefully (sprays straigt out until it hits the frame) on the passenger side and rear it does not come out as forcefully, comes straight out about a foot until it starts falling......any suggestions? are these extremely hard to bleed, is there an issue with the abs pump that can cause this?
by the way thanks for info in advance, i cant wait to get this car up and running, mods will be soon to come
