Thread: Power Steering Stiff After New Pump
Results 1 to 7 of 7
  1. #1 Power Steering Stiff After New Pump
    Grand Rapids, MI
    I recently put on a reman. A1-Cardone pump. However after a couple days of driving, it is still quite stiff. I was wondering what could possibly be my problem.
    Turning does not get better with higher RPM and it does seem a little easier to turn when you first crank it up but for the most part it's stiff all the way around all the time. However if it is idling and I try to turn the wheel it bogs the motor quite a bit.
    The old pump worked better than this one! What's going on??
    I plan to put TransTune in it to see if I can clean out the power steering rack.
    Any other thoughts?
    Thanks
  2. #2 Re: Power Steering Stiff After New Pump
    Jersey
    air in it?
    16' wrx sti- stock
  3. #3 Re: Power Steering Stiff After New Pump
    Grand Rapids, MI
    I assume there's no air in it. I had the cap off and went back and forth a thousand times.
  4. #4 Re: Power Steering Stiff After New Pump
    Grand Rapids, MI
    well i have decided the hell with it and i'm sending my cardone pump back and getting one from morads. will keep yall posted on how it goes.
  5. #5 Re: Power Steering Stiff After New Pump
    SE Level Member Prixer97's Avatar
    Jul 2011
    Fargo, ND
    Quote Originally Posted by brandonl2000 View Post
    Whats the verdict? My 97 is getting louder each day it seams. Who is Morads? How do they compare to AcDelco?
  6. #6 Re: Power Steering Stiff After New Pump
    PA
    Quote Originally Posted by Prixer97 View Post
    Morads is a company that dismantles used GM cars and sells the parts. Like an auto recycler.
    Give them a call Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    2001 GSE
  7. #7 Re: Power Steering Stiff After New Pump
    Grand Rapids, MI
    That verdict is long accomplished. I ended up getting a Morad used P/S pump and it worked EXCELLENT. But it's on my GT somewheres, I don't haz it anymore.
    But Morad is an excellent place to deal with and they are very quick about everything they do, very professional. GO with them.
  1. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  2. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  3. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
  4. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
