Thread: Vibration and fluctuating Speedo
Results 1 to 5 of 5
  1. #1 Vibration and fluctuating Speedo
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Hi guys,
    I went for a long drive with a couple of friends the other day, when I started getting some really bad vibration. It felt like the car was trying to shake itself apart. At the same time, my speedo (analog and on the HUD) started fluctuating, which also wouldn't allow me to engage cruise control.
    This happened on acceleration and while trying to maintain a constant speed (bit tricky without the speedo). When I let off the accelerator, the car and ride was smooth as silk.
    After doing a little research, I'm guessing maybe dirty/worn CV joints, since I haven't checked them in about 2 years (yes, stupid). Also, my guess is the fluctuating speedo and lack of cruise control is caused by the VSS, though I'm not sure if that's affected at all by CV joints.
    What do you guys think? Is there anything else I'm missing?
    Thanks for your help.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  2. #2 Re: Vibration and fluctuating Speedo
    Dec 2008
    UPDATE: Had my car up on a lift today, and turns out both my tie rod bushings are screwed, so I'll change that first and proceed from there. Don't know if that would affect my VSS or something to cause fluctuating speedo readings though.
  3. #3 Re: Vibration and fluctuating Speedo
    let's toast til we die brand121's Avatar
    South Carolina
    I had the same problem minus the speedo fluctuation, if you still have the vibration after replacing the tie rod ends, try replacing the cv axles.
    My couch pulls out, but, I don't...
  4. #4 Re: Vibration and fluctuating Speedo
    Dec 2008
    Quote Originally Posted by brand121 View Post
    Yep that sounds like a good idea and the next logical step. Thanks!
  5. #5 Re: Vibration and fluctuating Speedo
    Dec 2008
    UPDATE: Well, got my Tie Rod ends changed and the vibration is pretty much gone.
    However, my speedometer is still fluctuating both on the analog gauge and on the HUD as well as my OBD-II L67 Scanmaster. While this happens, my car shifts gear as the speed fluctuates, so I'm still not sure if its a bad speed sensor or a PCM issue.
    Any ideas?
    EDIT: My odometer works fine despite the fluctuating speedo.
  1. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  2. 94 GP with fluctuating temp gauge
    By Beyond Hope in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-22-2010, 09:19 AM
  3. Badly Fluctuating RPM's
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 08:07 AM
  4. Fluctuating gas gauge problem!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 04-11-2010, 04:06 PM
  5. Fuel Gauge Fluctuating
    By UTfanatic80 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 05:21 PM
