Thread: Rear brake upgrade question
Results 1 to 9 of 9
  1. #1 Rear brake upgrade question
    Greensburg, PA
    Would it be possible for me to run rear camaro rotors with a GXP rear caliper? Not sure of any dimensions of rotors and calipers so please no smart @$$ responses. thanks
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  2. #2 Re: Rear brake upgrade question
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    No, must be a complete GXP setup
  3. #3 Re: Rear brake upgrade question
    Greensburg, PA
    Thats kinda what i was figuring. thanx
  4. #4 Re: Rear brake upgrade question
    Greensburg, PA
    I've read the answer to this question but can't remember it or seem to find it so is it possible to run the rear camaro and caliper setup on out grand prix's and if it fits will i still have my parking brake?
  5. #5 Re: Rear brake upgrade question
    Las Cruces, NM
    Our only rear options are grand am or GXP. Unless you can still find the bear setup.
  6. #6 Re: Rear brake upgrade question
    Greensburg, PA
    Hey saw u just got a GXP rear upgrade. hwere did u go about getting the calipers pads and rotors from? If got a F-body front on the way and want to get the rear outta the way at the same time
  7. #7 Re: Rear brake upgrade question
    Las Cruces, NM
    I got them from www.strickerbros.com
  8. #8 Re: Rear brake upgrade question
    Apr 2008
    Bremerton, WA
    What size rotors (11" or 12"?) and what type of calipers (aluminum dual piston?)come on the GXP, and what years did they make the GXP? Thanks for any info!
    TC
  9. #9 Re: Rear brake upgrade question
    Pittsburgh
    Waht about the 11.5 rear rotors from the Lucerne? ANybody try this?
  1. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  2. First upgrade...
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-13-2008, 11:13 AM
  3. Upgrade Recomendations
    By Risinnfallen in forum General Tech Discussion
    Last Post: 04-19-2008, 03:28 AM
  4. When is the Non-HD to HD Trans Upgrade Needed
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2008, 03:53 PM
  5. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
