Thread: brake caliper bolt torque specs?
Results 1 to 7 of 7
  1. #1 brake caliper bolt torque specs?
    Feb 2009
    West Michigan
    Anyone know the torque specs for an 05 GP GT:
    Front caliper bracket bolt?
    Front caliper pin bolt?
  2. #2 Re: brake caliper bolt torque specs?
    Charles City, IA
    Caliper bolt-50ft
    Caliper braket bolt-100ft
    I never torque them just get them close to those numbers in feel and you will be good.
    SMGPFC Two Nipple General
  3. #3 Re: brake caliper bolt torque specs?
    Feb 2009
    West Michigan
    Thanks for the info!!!!
    I forgot to ask in my original post but are the torque specs the same for the rear?
  4. #4 Re: brake caliper bolt torque specs?
    GT Level Member donmega's Avatar
    St louis, mo
    alldata says 180nm for bracket bolt
    95nm pin
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  5. #5 Re: brake caliper bolt torque specs?
    Feb 2009
    West Michigan
    Quote Originally Posted by donmega View Post
    95nm pin
    180nm = 133 ft lbs
    95nm = 70 ft lbs
    Are these the torques specs for the rear? or front and rear?
  6. #6 Re: brake caliper bolt torque specs?
    St louis, mo
    the front
    the rear is
    bracket = 120nm
    pin = 34nm
  7. #7 Re: brake caliper bolt torque specs?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Front disc brakes
    Bleeder valve, front caliper 115 in/lbs
    Brake hose caliper bolt 40 ft/lbs
    Caliper bolts 63 ft/lbs
    Caliper bracket bolts (requires loctite) 137 ft/lbs
    Rear disc brake
    Bleeder valve 97 in/lbs
    Brake hose bolt 32 ft/lbs
    Caliper bracket bolt (requires loctite) 92 ft/lbs
    Caliper bolt 32 ft/lbs
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Caliper Mounting Bracket Bolt
    By Paintball0027 in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2010, 11:14 AM
  2. TB bolt torque specs
    By Warbeaver in forum General Tech Discussion
    Last Post: 04-14-2009, 02:51 PM
  3. Looking For Some Torque Specs.
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 07-10-2008, 02:58 PM
  4. Caliper pin bolt
    By IndeedSS in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2008, 12:29 PM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
