Thread: Swaybar Sizes
Page 1 of 11 123 ... LastLast
Results 1 to 20 of 219
  1. #1 Swaybar Sizes
    Donating User Odi's Avatar
    Chicago South Suburbs
    For future reference 97-03,
    Stock Front - 28mm - Hollow
    Stock Rear - 17mm - Hollow
    GMPP Front - 34mm Hollow
    GMPP Rear - 19mm Solid
    Progress Front - 34mm Solid
    Dorman Front - 34mm Solid
    SLP Front* - 34mm Solid (35?)
    SLP Rear* - 19mm Solid (25?)
    BMR/Addco/Speedbuilt/Next Level Front - 32mm - Solid
    BMR/Addco/Speedbuilt/Next Level Rear - 22mm - Solid
    RAT Front - 38mm - Solid
    RAT Rear - 27mm - Solid
    Availability of most of these is limited. RAT are no longer made.
    Apparently some users reported different sizes for SLP's. I got mine from craigslist so I'm unsure if they're legit SLP's or someone combined a different set.
    Quote Originally Posted by SomeDudeAtHome View Post
    So I just received my SLP sway bars from UPS today. The rear bar is definitley NOT 25mm. I'd say it's closer to 19-20mm. I didn't have time to measure them before leaving for work. Also I'd say the front is actually 34mm and not 35. The 35mm bushing I have for it did not fit snug around the bar but had about a 1mm gap. Maybe that's normal and there's suppose to be that much room. I thought it was suppose to be pretty snug around the bar though. If the front is 34mm and the rear is as small as I think I'm going to be returning them and buying other bars.
    SLP's on sale from 3800 report 1 3/8" thick for the Front and 5/8" thick for the Rear Sway Bar.
  2. #2 Re: Swaybar Sizes
  3. #3 Re: Swaybar Sizes
    Coulda sworn my GMPP was the exact same size as stock but just solid instead of hollow.
  4. #4 Re: Swaybar Sizes
    Donating Users chrisb's Avatar
    Bucyrus, OH
    I believe the front gmpp is solid, the weight difference is significant over a stock one
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  5. #5 Re: Swaybar Sizes
  6. #6 Re: Swaybar Sizes
    GT Level Member neel2008's Avatar
    Huntington, IN
    So does anyone know for sure if the front GMPP is solid or hollow? Seems weird that they would go from hollow rear to solid rear but leave the front hollow.... But then again the front increases 6mm and the rear only increases 2mm so maybe thats why....
    97gtp
  7. #7 Re: Swaybar Sizes
    you're fail, those links didn't tell me what the stock size is.
  8. #8 Re: Swaybar Sizes
    Bucyrus, OH
    I kno hes right on the size, I had a hell of a time finding a poly bushing at the time that would fit it
  9. #9 Re: Swaybar Sizes
    why dont u measure it then?
  10. #10 Re: Swaybar Sizes
    because its cold outside and i dont have a caliper?
  11. #11 Re: Swaybar Sizes
    Pennsylvania
    Any different for 04+? How about Comp G/GXP?
  12. #12 Re: Swaybar Sizes
    with 04+ if i remember correctly u need 97-03 LCA's in order to mount the front aftermarket swaybars. otherwise i think theyre the same, comp g's might have them bigger, not sure. gxp's also a different ball game.
  13. #13 Re: Swaybar Sizes
    GT Level Member ill12will8's Avatar
    DC/MD
    how difficult is it to install the front sway
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  14. #14 Re: Swaybar Sizes
    Quote Originally Posted by MiriV View Post
    04/05 only.
  15. #15 Re: Swaybar Sizes
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Quote Originally Posted by ill12will8 View Post
    I second this ???
  16. #16 Re: Swaybar Sizes
    not that difficult. hardest part is wiggling it in and out, unbolting and bolting it back in is cake.
  17. #17 Re: Swaybar Sizes
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Someone should add which ones we can pull out of a junkyard for an upgrade. If I remember correctly some of the other W-body cars came with the GMPP bar...Impala, Monte Carlo?
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  18. #18 Re: Swaybar Sizes
  19. #19 Re: Swaybar Sizes
    Jul 2010
    Holyoke, MA
    any cop car had the gmpp stuff on it.
    Cops around here only drive Crown Vic's and Charger's...
  20. #20 Re: Swaybar Sizes
    $10 at Sam's for a Monte/Impala bar..
  1. Swaybar Brackets...
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2009, 01:07 PM
  2. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
  3. Largest available rear swaybar?
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2009, 10:02 PM
