Thread: rear sway bushing?
Results 1 to 4 of 4
  1. #1 rear sway bushing?
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    I have the gmpp rear sway and I wanna do poly bushings.............I ordered a set of bushings from energy suspension and the bracket needs to be modified but my friend with all the necessary equipment is not in the states right now (due to he is in the service) so I am at a stand still with my rear bar.my question is,is there anywhere you guys could suggest I go to get a set of rear poly bushings with the correct bracket so I can finally be done with it or can someone here modify the brackets that came with the energy suspension set to fit the prix?
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  2. #2 Re: rear sway bushing?
    bend the stock brackets to make them fit.
  3. #3 Re: rear sway bushing?
    Apr 2011
    MICHIGAN
    Wish it were that simple but the bushing that came with the set is smaller than the stock bracket.I was told I could cut or shave the bracket that came with the energy suspensions but the guy who told me it could be done said it would still need to be bent.
  4. #4 Re: rear sway bushing?
    I put the bushing on the bar then pushed the bracket until i could get the bolt in then ran it in the rest of the way with an impact.
  1. Shot rear LCA rubber bushing, what can be done?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 08:54 AM
  2. gmpp rear sway bar help
    By stanbob123 in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2010, 09:29 PM
