My Rear Right brake pads seems to have worn unevenly. I'm wondering if it's because of the pin not moving smoothly. On the front pads the pin/bolt seems to be the same thing and I lubed that up before reinstalling. But the rear pin and bolt are two different parts it seems. What is a good way to take off the rear pin and lube it so that I make sure the new pads wear evenly. I don't want to need new pads again. Thanks!!
edit: I think i found how to remove the rear pin based on some youtube videos of similar style pins from other vehicle makes. I'll update when I've finished the job tomorrow.
