Thread: The Big Bad Brake Thread
Page 12 of 33 FirstFirst ... 2101112131422 ... LastLast
Results 221 to 240 of 647
  1. #221 Re: The Big Bad Brake Thread
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    At any rate more than stock GP suspension can handle.
  2. #222 Re: The Big Bad Brake Thread
    Mar 2012
    Phoenix Arizona
    hello qustion on the brake up grade 05 -08 gxp is what im looking for i read some were tht the setup will work on chevy o1 monte carlo ss 17" wheels this correct and if so what parts should i be looking to find new or uses pleaz send me a list
  3. #223 Re: The Big Bad Brake Thread
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    Has anyone had experience with Power Stop Evolution Ceramic Brake Pads? If so, opinions on them? I need new pads so I'm looking at performance vs. price right now cause I don't want to spend a bunch of money on them. Thanks.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  4. #224 Re: The Big Bad Brake Thread
    Jun 2011
    Im looking at doing the:
    Bigger is always better, The GXP upgrade!
    This will work on my car right?
  5. #225 Re: The Big Bad Brake Thread
    Yes, just get the GXP calipers and GXP rotors and GXP pads
  6. #226 Re: The Big Bad Brake Thread
    Donating User Odi's Avatar
    Chicago South Suburbs
    dave, when will you add some 06+ impala brake info?
  7. #227 Re: The Big Bad Brake Thread
    Jun 2011
    Thanks Dave.
    Do i need GXP pads?
    My new Wagner ThermoQuiet Brake Pads wont work?
    This will most likely be my next project.
  8. #228 Re: The Big Bad Brake Thread
    I should clean up those calcs I did first.
  9. #229 Re: The Big Bad Brake Thread
    Quote Originally Posted by E IN v Y View Post
    Thanks Dave.
    Do i need GXP pads?
    Calipers, rotors and pads.
    Pads because your going from a single piston to a dual piston, bigger area.
  10. #230 Re: The Big Bad Brake Thread
    Jun 2011
    OK cool. Last question for now.
    Will my old 17" SE rims work with these? ( i may use them in the winter)
    Will my Concept 9s work? lol ppl here say they look too small.
  11. #231 Re: The Big Bad Brake Thread
    ^^ 17 and up fits over gxp calipers.
  12. #232 Re: The Big Bad Brake Thread
    GT Level Member 40th GP's Avatar
    Utah
    Ok, so I just read through 13 pages of more brake info than I know what to do with, but I am still ocnfused. I am just wanting to do a quick and simple 12 inch upgrade to get the most bang for the buck. I am hitting the bone yard today to see what I can find. Can anyone tell me exactly what I need from what donor vehicle.
    From what I gather my options are the following:
    -calipers, rotors, and pads from a 04-08 grand prix (do I not need the brackets???)
    -brackets and rotors from a 01+ monte carlo or impala
    -brackets, rotors, pads, calipers from a 98-02 f-body
    Am I correct here? I am probably going to go with whatever set up I can find in the yard, so I am not going to be too picky. Assuming the have a donor f-body, what is the hardware kit I am reading about? Does the above not include everything needed? I also see that we are needing spacers, but that the zzp kit includes 14mm bolts that I guess eliminate the need for spacers? If so, couldn't I just go to the hardware store and get the 14mm bolts?
    Sorry if this is lame, there is just so much info here and it is not broken down very well for exactly what is needed for the various options. It would also be nice to have a picture how-to, but the one referenced is not showing the pictures for me for some reason.
    I appreciate any input, and thanks in advance.
  13. #233 Re: The Big Bad Brake Thread
    the difference in rotor size mainly contributes to heat capacity rather than braking force.
    f body requires tapped brackets or spacers/sleeves.
    06+ impala provides the same braking force as F body but is 100% bolt on, cheaper, and iron calipers for better pedal feel/no risk of clamshell.
    Pedal feel difference is probably negligible.
    F body is known to clamshell.
  14. #234 Re: The Big Bad Brake Thread
    Utah
    What is needed to do this from the 06+ Impala--the brackets, rotors, and calipers?
    So at the yard I found a 2003 POLICE Impala (although I don't think the brakes were any different than the normal). I scabbed the brackets for $5 each, so for only $10 more than it would have cost to do the brakes anyway I got the 12 inch upgrade (they did not have ANY late model F-bodies). Not bad, but I am still interested in the 06+ Impala info.
    You need calipers/brackets, pads, rotors all from an 06+ impala.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    06+ impala you can replace all 4 rotors/calipers right? Not just like the front 2?
    Rears arent an upgrade.
    You dont need rear brakes unpes you have coilovers basically.
    Even then, for the 97-03 guys the gxp rears are just looks/heat capacity. No significant increase in stopping power.
    Mar 2012
    Minneapolis MN
    So you don't need them. Thank you for clearing that up, I know I had read that the front takes like 97% or more of the stopping but I wasn't sure.
    Off the the Pick and pull I go
    There goes my paycheck lol
  19. #239 Re: The Big Bad Brake Thread
    Jun 2011
    I want to run a C5 setup.
    Would a 20$ Advance Auto 02' camaro bracket work?
    Yes.
  1. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  2. Another with these fit, what do you think thread!!!
    By kjclawson in forum Tires & Wheels
    Last Post: 08-03-2010, 08:35 AM
  3. ^ thread
    By GreenPrix in forum Off Topic Discussion
    Last Post: 01-02-2010, 11:58 PM
  4. My car pic thread
    By thelongone13 in forum Off Topic Discussion
    Last Post: 02-11-2008, 11:23 AM
