Thread: Dropped my car...camber is off.
Results 1 to 20 of 28
  1. #1 Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    Im not positive that there isn't already an answer out here.. but i haven't been able to find it...
    Here's the problem in the spring i dropped my car. The springs are Eibach sportline which is a 1.7-2.3 drop.. Since then i've notice the camber is off.. I've had the alignment completed but this didn't correct the camber issue.. the inside of my tires are getting extra wear and with driving around 500 miles a week.. I'm ripping through my tires.. Any suggestions or answers will be appreciated.
  2. #2 Re: Dropped my car...camber is off.
    Donating User Odi's Avatar
    Chicago South Suburbs
    camber bolts baby, you need them. you should ***** at the alignment guys that did it, they shouldhave told you about that.
  3. #3 Re: Dropped my car...camber is off.
    Charles City, IA
    Dont buy camber bolts just have them grind the strut. If they do not know how to do that dont let them touch your car.
    SMGPFC Two Nipple General
  4. #4 Re: Dropped my car...camber is off.
    adjusting camber is easy when you open up the holes on the strut like ^^^ said.
  5. #5 Re: Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    yeah see i wasn't sure.. i heard that there are things that can be bought... so getting the struts grinded is the best route?
  6. #6 Re: Dropped my car...camber is off.
    Nov 2009
    Grand haven
    listen to the god's ^^^^
  7. #7 Re: Dropped my car...camber is off.
    Kansas
    how much would it be to grind those down?
    SOLD 1999 GT Silvermist TS
  8. #8 Re: Dropped my car...camber is off.
    It costs patience
  9. #9 Re: Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    i have a feeling they aren't going to be to sure on what needs to be grinded.. and since i'm not sure myself.. whats needs to be grinded??
  10. #10 Re: Dropped my car...camber is off.
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    the upper bolt holes on the strut "ears" need to be elongated into a slot, so that the knuckle can be rotated. I believe the FSM or a TSB specifically outlines what should be done. Does anybody know which it is?
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  11. #11 Re: Dropped my car...camber is off.
    Jul 2010
    upstate NY
    My camber was off after installing new struts all around. About a degree negative on the fronts and about 1.5 degs on the rears. Pretty even side to side. The shop wanted $400 to pull all the struts and elongate the holes (as described above). I told them no thanks. Now 4,000 miles later, I still don't see any abnormal wear.
    However, since you are having tire wear problems, the cheapest approach would be to get the camber bolts. Less than $30 a pair, all you have to do is replace the upper bolt on the bottom of each strut with the camber bolt and then go get an alignment.
  12. #12 Re: Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    alright heres the next question...any one live in or near cleveland that has done this themselves??
  13. #13 Re: Dropped my car...camber is off.
    Jun 2010
    Christiansburg, VA
    Another thing: check to make sure your toe-in/out is dialed in properly. I've found that toe has a far greater impact on tire wear than camber does.
  14. #14 Re: Dropped my car...camber is off.
    Quote Originally Posted by hklvette View Post
    this 100%. negative camber doesnt accelerate wear on tires unless you run a good amount (>5* ish). toe will demolish tires when its off.
  15. #15 Re: Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    yeah i've had an alignment down but the guy told me that he can't adjust the camber...ride is straight and wheel is straight no pull to either direction... just you can look at the wheels and see the camber is off... i think it's negative camber the tops of the wheels are leaning in toward the car... in worse on some wheels.. not as bad on others. but overall its wearing me tires down fast bc i drive so much.
    2003 Subaru Impreza WRX
    2008 Saturn Aura
    2000 Bright Red GTP coupe. RIP 11/6/11
  16. #16 Re: Dropped my car...camber is off.
    Minnesota
    You can pay to have the bolt holes elongated or have them install a camber kit on each wheel.
  17. #17 Re: Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    2008 Saturn Aura
  18. #18 Re: Dropped my car...camber is off.
    Minnesota
    Quote Originally Posted by Ballin00gtp View Post
    That is what I have on my car. I have KYB AGXs and Vogtland springs and it works good for me.
  19. #19 Re: Dropped my car...camber is off.
    Jul 2010
    upstate NY
    Sorry. I'm over in the NY capital district.
    With a floor jack, impact wrench and BFH, putting in the camber bolts would be a 30 minute job (for the fronts)
  20. #20 Re: Dropped my car...camber is off.
    Donating Users
    Parma, Ohio
    alright cool thanks for all the input... hopefully this will correct it. bc having to buy tires every year gets costly
    2008 Saturn Aura
  1. Dropped Boost After Headers
    By KFCOrBust in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 02:07 AM
  2. Friend Dropped my Hood.
    By Spartan GL in forum The Rant Forum
    Last Post: 03-01-2010, 07:48 AM
  3. tuned and pulley dropped
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-26-2009, 11:57 AM
  4. Weird noise. Dropped the car in second.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-04-2008, 12:26 PM
