Thread: "abs" and "trac off" lights staying on?
Results 21 to 40 of 41
  1. #21 Re: "abs" and "trac off" lights staying on?
    May 2008
    Burlington, ON
    Hello, my trac and abs lights were going on and I was getting the crunching feeling when braking at slow speeds (under 15 mph) like the abs brakes were engaging. I replace a front hub assembly and all was fine.
  2. #22 Re: "abs" and "trac off" lights staying on?
    GTP Level Member dstout's Avatar
    ky
    Hey guys,
    Kinda new around here but I have been around on the other boards for a while,
    Anyway, I had a problem last year with my ABS and Trac lights lighting and not going out till I shut off the car.
    The dealer scanned the car and the ABS module was bad.....new dealer part was between $1,200.00 and $1,500.00. the same part from morads was $175.00 shipped.
    The ABS module has two parts, the pump and the computer...I'm sure there is a more technical name for these parts but a computer and pump but, it is what it is.
    The computer of the module was bad once I changed the part everything was good.
    It's hard to tell what the problem is without codes....I think pepboys will scan it for free.
    I would get it scanned so you don't have to replace something that isn't bad.
    Hope this helped a little bit.
  3. #23 Re: "abs" and "trac off" lights staying on?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    dstout, you're absolutely correct, it's much easier to pinpoint if you can scan, but unfortunately, most scanners won't scan abs codes, including the scanners the parts places would use. You have to have something like a Tech II, Snap-On, or HP Tuners.
    2001 Buick Regal LS - Almost Stock
  4. #24 Re: "abs" and "trac off" lights staying on?
    Jan 2009
    hammond, IN
    mine did the samme thing and i had to replace the wheel hub
  5. #25 Re: "abs" and "trac off" lights staying on?
    SE Level Member Red97GPGT's Avatar
    grand rapids, MI
    To the guy who replaced the front hubs try doing the rears. To the original poster, definitely wheel bearing/hub assembly. The hub going bad will cause lots of issues, including your power steering acting up, your ABS turning off, traction control turning off...and more. They are actually pretty easy to change out. Take off the wheel, axel nut, 2 caliper bolts, 3 bolts for assemble and voila, reassemble.
  6. #26 Re: "abs" and "trac off" lights staying on?
    Jan 2009
    hammond, IN
    Quote Originally Posted by Red97GPGT View Post
    ya i have never changed the rears lol but the front was very easy to do
  7. #27 Re: "abs" and "trac off" lights staying on?
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    just had my lights come on also today!!! '02 GT
    whats up with that!
    any help any one gives is helpful, I'm tracking this thread too!!!
    hydro-powered
  8. #28 Re: "abs" and "trac off" lights staying on?
    Jan 2009
    hammond, IN
    its probably the wheel hubs,that was my problem. i replaced them in the front and the lights turned right off
    (sold)GTP-Intense pcm,zzp 3.4 pulley, colder plugs, zzp dp, magnaflow converter, k&n intake, autometer gauges, zzp motor mounts, u bend delete, res delete, 180 stat
    1997 lt1 formula- to many mods to list.
  9. #29 Re: "abs" and "trac off" lights staying on?
    SE Level Member Dropped GP GT's Avatar
    Dec 2008
    Wyoming, MI
    I had the same problem especially when the roads were wet. I had to replace the wheel bearing and never had that problem again
  10. #30 Re: "abs" and "trac off" lights staying on?
    grand rapids, MI
    for some reason I never caught the fact that my front passenger wire from the hub to the sensor was completely severed. I replaced both front hubs (paid $100 shipped for both!) and all my lights are back off. Easy job!
  11. #31 Re: "abs" and "trac off" lights staying on?
    Apr 2009
    Portsmouth VA
    The sensors are not removable (with out a big hammer) and will be changed with the bearings. I have changed my front hubs and my EBCM and I still have the TCS off light on (ABS went out when I changed the ECBM) I want to know how to test the rear WSS with a voltmeter. I hear it is possible but I can't find the specifics.
  12. #32 Re: "abs" and "trac off" lights staying on?
    Apr 2009
    temecula, CA, 92591
    I had a similar problem since a few months, I changed a hub and it started again one month later but it was really rare, I did a flush, we went to vegas, like 600miles in the trafic and no problems. and since a few days it is just crazy, the abs start crunching right away when I start driving, even when I'm not braking. I did a new flush, change the pads, my friend told me maybe I need to change the ABS pump, I will check the connections tomorrow, I hope it is not too bad, I do not have one penny for that and I need my car.
    The brake fluid was very dark, and I know I need to change a tie rod, maybe this is the second hub too.
    If I disconnect the sensors one by one and drive the car to see if this is a sensor pronblem do you think it will work or not,
    Is that possible to just disconnect the ABS, the time for me to find some financial solutions, this crunching noise and sensation make me totally crazy !!
    I'm lost and desesperate
    Thanks for all your help
  13. #33 Re: "abs" and "trac off" lights staying on?
    Apr 2009
    temecula, CA, 92591
    OK, a "technician" saw the car and said, "...mmmm you need to change ABS module and Computer....mmmmm..."
    So I made some research on the net, and I found something about the wiring between the hub and the car and a possible bad connection at the plug, I removed everything, check the wires, cleaned the connection, and now it is back to normal,, well for the moment...
  14. #34 Re: "abs" and "trac off" lights staying on?
    PA
    Quote Originally Posted by tech View Post
    I think a lot of the problems with lights like this is the connections. Whenever I get a light on, I always check all my connections, make sure they are clean, and use some dielectric grease in them. Usually works for awhile.
    2001 GSE
  15. #35 Re: "abs" and "trac off" lights staying on?
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    i dont have the crunching feeling that you guys are talking about but my Trac control and ABS lights are both on. As ive read, i should check the connections to the sensors? how do i do this?
    SPREAD THE JAM
  16. #36 Re: "abs" and "trac off" lights staying on?
    Feb 2009
    Illinois
    anyone?
    SPREAD THE JAM
  17. #37 Re: "abs" and "trac off" lights staying on?
    Apr 2009
    temecula, CA, 92591
    two solutions, you jack the car, you remove the wheels one by one and you'll see a wire behind each hub, this is the wires for the sensors. or you have a gooooood friend with a lift and it will be much more easier to just lift the car and check them
  18. #38 Re: "abs" and "trac off" lights staying on?
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    mine are constantly on and thats because i know there bad and when u had the engine rebuilt i had the car parked and the emergence brake on for like 6 months straight so im 99% sure its the hubs. seeings how the front is the important ones check the front ones first before dealing with the back
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  19. #39 Re: "abs" and "trac off" lights staying on?
    Hutto TX
    I recently had this happen (ABS/TCS lights come on, steering stiff). I checked the sensors/wiring at the hubs, all seemed good. Decided to check the big connector on ABS module. I removed, cleaned, and reseated the connector, and haven't had a problem since. It is a big connector, and after 13 years of pretty extreme conditions not surprising it needs a bit of love. Worth trying before anyone sends off the module for refurb, or even spend $100 on a scan.
    Quote Originally Posted by john9472 View Post
    Hello,
    my "abs" and "trac off" lights stay on about 50% of the time. They generally come on soon after (or at) start up and stay on until I shut the car off. I also experience my brake pedal crunching or going soft at slow speeds (below 30 kmh) about 30% of the time as if the abs system is becoming active. I have just replaced the pads front and back. Any ideas? Thanks.
  20. #40 Re: "abs" and "trac off" lights staying on?
    Westminster
    My ABS and Trac Off lights come on occasionally then eventually go off. No other symptoms at this point. I was under the car checking for loose wires and noticed that the passenger side CV boot failed and there is quite a bit of grease there. That particular hub had been changed due to being noisy a couple of years ago.
    i bought an Innova 3150b scanner that is supposed to read ABS. But the codes it gives me in the ABS setting are like 16, 22, and 45. When I look them up they appear to be codes that don't pertain to the ABS system. I've called Innova and they are supposed to call me back Monday.
    I know I have to replace the axle, do you think that the grease could cause the speed sensor to have failed? Any other ideas?
  1. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
  2. "Calibrated" A/F Gauge, are they worth it?
    By GeddyLee in forum Visual/Body Modifications
    Last Post: 02-12-2008, 03:16 PM
  3. "Mark All As Read" option?
    By VinnieGTP in forum Forum Bugs/Suggestions
    Last Post: 01-06-2008, 12:03 AM
  4. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
