Thread: after tie rod repair- front creaking noise only while moving
Results 1 to 2 of 2
  1. #1 after tie rod repair- front creaking noise only while moving
    Jul 2010
    Warrington, PA
    Hi - I have a 2000 GTP, 135k. I replaced the inner and outer tie rods, and had the car aligned. After this, I started hearing this creaking noise which increased in frequency the faster I go. I never heard this noise before. When stopped, there's never a noise even if I try to bounce the front end. Bumps don't change the noise. I also notice when I start to turn right it goes away.
    I jacked up the front end and spun both wheels - no noise. Inspected for anything which could be rubbing against the axle/CV joint and tires - also looked at brakes - all seemed ok.
    It's weird that all this started after the tie rod and alignment. Weirder still, I got someone to ride with me to hear the noise and it was gone. Then when they left it came back. Could the added passenger weight have an effect?
    Any opinions appreciated otherwise I'll have to start replacing things I guess
  2. #2 Re: after tie rod repair- front creaking noise only while moving
    Nov 2009
    Grand haven
    Lower ball joint?
  1. Creaking Popping noise from front end.
    By nawarkk in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2010, 06:21 PM
  2. Front end noise
    By squirrel in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 10:50 PM
  3. front end noise, what else...?
    By Jakegday in forum General Tech Discussion
    Last Post: 07-30-2010, 08:22 PM
  4. Creaking noise
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 11:42 PM
  5. front end noise, hub?
    By hourang in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2010, 11:17 AM
