Thread: Top of the struts under hood
Results 1 to 9 of 9
  1. #1 Top of the struts under hood
    Akron Ohio
    How loose should they be? I push down in the front of my car and they come up.
  2. #2 Re: Top of the struts under hood
    Nov 2009
    Grand haven
    LOL get some struts and strut mounts.
  3. #3 Re: Top of the struts under hood
  4. #4 Re: Top of the struts under hood
    Portland Oregon
    Are you lowered? I've seen this happen on lowered cars sometimes.
  5. #5 Re: Top of the struts under hood
    Quote Originally Posted by OH4CompG View Post
    then they need pogo washers.
  6. #6 Re: Top of the struts under hood
    Portland Oregon
    Duh...
  7. #7 Re: Top of the struts under hood
    Akron Ohio
    no im stock
  8. #8 Re: Top of the struts under hood
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Mine did the same thing. I heard about the pogo washers and made my own.My shocks were good at the time too.I used some actual washers from rural king.Doesnt look 2 bad ether.
  9. #9 Re: Top of the struts under hood
    HUDSON
    All that is needed is thicker washer under the factory cup. You can remover the factory cup by romoving the center nut, and install a thicker washer under the factory cup to tighten up on the bushing. You can actually adjust your ride by how thick the washer is and is putting pressure on the bushing.
    AN impact wrench mackes removing and reinstalling the center nut a sinch.
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  3. Anyone with KYB struts
    By archemedes in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2008, 06:57 AM
