Thread: Have a squealing, sounds like brakes but it's not
Results 1 to 6 of 6
  1. #1 Have a squealing, sounds like brakes but it's not
    Jan 2009
    Tallahassee, FL
    I got a loud squealing that coming from the front passenger side of the car. It only happens for a couple of seconds when I turn or am accelerating from a stop up to say 10 mph. It's a squeal that sounds like bad brakes would but the brakes aren't squealing at all stopping no matter how hard. The axle, hub, and brakes are all about a year old as well. Anyone have ideas?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Have a squealing, sounds like brakes but it's not
    Michigan
    check your brakes to see if something is sticking or rubbing if you haven't already.
  3. #3 Re: Have a squealing, sounds like brakes but it's not
    GT Level Member sasquatch094's Avatar
    cleveland
    i have a squealing but only in reverse. igot it right after i replaced my rotors and pads.. I even replaced the pads a second time after that.. im in the same situation you are.. this sucks lol
  4. #4 Re: Have a squealing, sounds like brakes but it's not
    Jan 2009
    Tallahassee, FL
    Yea it's bugging the crap out of me, popped up out of nowhere. It only does it turning left slow and when moving from a stop. Squeals like 3 times then goes away, nothing while cruising.
    77 Morris Garage B
  5. #5 Re: Have a squealing, sounds like brakes but it's not
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    check for a rust ridge on the rotor..sand it down. mine had some rust creeping over that was contacting the clip on my pad
  6. #6 Re: Have a squealing, sounds like brakes but it's not
    cleveland
    i found out my problem, a spacer for the wheel bearing was just nipping the rotor at the bottom.. some kind of tab
  1. Exhaust Sounds
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 12:20 AM
  2. sqeaking/squealing in engine bay
    By CTKGP09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 01:18 AM
  3. This name sounds so familiar
    By JCG's-GTP in forum Off Topic Discussion
    Last Post: 02-15-2009, 11:10 PM
  4. Squealing Noise
    By eXceL(FAM) in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 07:49 PM
