Thread: Time for first brake job. To upgrade or not???
Results 1 to 11 of 11
  1. #1 Time for first brake job. To upgrade or not???
    Ohio
    Ok so I have had this car for almost 2 months now and its about time I replace the brakes all the way around because from sitting the rotors rusted to **** and the rough surface is eating up the pads so they wont make it through the winter.
    So the question is do I just go to autozone or maybe rockauto and grab pads and rotors all the way around and spend like 250 for lifetime gold ceramic pads and 2yr rotors? OR do I upgrade to something possibly cross drilled and slotted with some pads that have more bite?
    Any thoughts or ideas?
    Also since I dont have a signature yet and nobody reads minds I have an 05 Grand Prix Base
  2. #2 Re: Time for first brake job. To upgrade or not???
    12" upgrade is cheap and effective if you want to put down ~$120 for everything at the most.
  3. #3 Re: Time for first brake job. To upgrade or not???
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    ^Agreed, Big difference in stopping power.
    And no drilled rotors, always plain or slotted.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  4. #4 Re: Time for first brake job. To upgrade or not???
    Feb 2008
    yes ^^
  5. #5 Re: Time for first brake job. To upgrade or not???
    GTX Level Member cerick08GP's Avatar
    Well, IMHO since your 05 already has big/better OEM brakes than the 97-03 models going bigger isn't really necessary. You could still upgrade, obviously. However your stock sized rotors with like Hawk HPS or EBC red stuff pads are very effective at stopping a GP.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: Time for first brake job. To upgrade or not???
    Ohio
    Dont the 04-08 come with 12" rotors standard?
    So if I already have 12" rotors then I just need to find a better pair than the OEM ones that are still on from the factory. (BTW car only has 21k thats why its still all original) So what should I look for for both front and rear?
    Moving on to pads again open to opinions lol
    And finally the biggest question is calipers. Is it worth upgrading? I have read some threads about getting dual piston calipers and everything. Should I look into this? I looked on rockauto and found GXP dual piston calipers but idk if they will fit or not and I remember someone saying the impalas had an option for dual piston calipers.
    Let me know what u think I still have some time before I pull the trigger
  7. #7 Re: Time for first brake job. To upgrade or not???
    Quote Originally Posted by cerick08GP View Post
    Just do what this guy said.
    Pick one of those two pads and get quality rotors and you'll like what you get.
  8. #8 Re: Time for first brake job. To upgrade or not???
    Drilled and slotted FTW. I don't care what you peeplz say I loved mine even on stock sized brakes with D/S'd rotors/new EBC red stuff pads...awesome compared to stock rotors and junk-o pads. Just sayin'...
  9. #9 Re: Time for first brake job. To upgrade or not???
    it was the EBC's....
  10. #10 Re: Time for first brake job. To upgrade or not???
    Banned
    waterford
    drilled and slotted ya chooch it
  11. #11 Re: Time for first brake job. To upgrade or not???
    Topeka, KS
    Ya cooch it ??? does that even mean.
  1. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  2. Brake upgrade
    By rocket69GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2010, 12:35 PM
  3. Time to upgrade!!!
    By WackyWRZ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2009, 11:19 PM
  4. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
