Thread: Vibration when hitting the brakes at speeds above 30mph
Results 1 to 17 of 17
  1. #1 Vibration when hitting the brakes at speeds above 30mph
    SE Level Member IFrees's Avatar
    Illinois
    I'm trying to figure out what I need to check or replace on my 2002 grand prix 98000 miles...... Seems to be a vibration when hitting the brakes even slightly or mashing on them. I'm thinking rotors? or maybe just a simple balance?
  2. #2 Re: Vibration when hitting the brakes at speeds above 30mph
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    sounds like warped rotors!!! If it was balance then it would probably shake while just driving!!!
  3. #3 Re: Vibration when hitting the brakes at speeds above 30mph
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    Quote Originally Posted by timmysgtp View Post
    ^^^ what he said
    2007 Grand Prix GXP
  4. #4 Re: Vibration when hitting the brakes at speeds above 30mph
    Outer Space
    Quote Originally Posted by Lenny View Post
    ^^^ what he said
    ^^^^ What those two guys said.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: Vibration when hitting the brakes at speeds above 30mph
    Willoughby, Ohio
    its the rotors i feel your pain
  6. #6 Re: Vibration when hitting the brakes at speeds above 30mph
    Quote Originally Posted by IFrees View Post
    could be the ball joints as well they are easy to check, or have checked. unless your brakes are old and u beat the daylights out of them, then i would think warped rotors.
  7. #7 Re: Vibration when hitting the brakes at speeds above 30mph
    Illinois
    Thanks for the help guys.... just purchased the car about a week ago it was either going to be a hub or rotors..... ordered some rear rotors since i can hear it a little more in the rear end. Lets try the cheap route first. I'll let you know what I find
  8. #8 Re: Vibration when hitting the brakes at speeds above 30mph
    SE Level Member Hawkeye1975's Avatar
    nj
    Had ok luck with cheap ones from Advanced, maybe $40 bucks each.
  9. #9 Re: Vibration when hitting the brakes at speeds above 30mph
    May 2008
    I had vibration during braking after I replaced my sway bars, lateral arms, and trailing arms. Turns out I needed to tighten one of the rear trailing arm bolts at the front end.
  10. #10 Re: Vibration when hitting the brakes at speeds above 30mph
    Illinois
    .. Def the left rear rotor missing half of the surface!! Tried to upload a picture but says file size is to big when its only 25KB. Thanks for the help guys!
  11. #11 Re: Vibration when hitting the brakes at speeds above 30mph
    Willoughby, Ohio
    holy crap keep an eye on those from now on!
  12. #12 Re: Vibration when hitting the brakes at speeds above 30mph
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    I eventually gave up and got a photobucket.... makes it much easier now, despite never wanting to get one. Then you just link the pics over.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  13. #13 Re: Vibration when hitting the brakes at speeds above 30mph
    Willoughby, Ohio
    ^^^ i use it all the time it really isnt one of the easiest ways to post pics
  14. #14 Re: Vibration when hitting the brakes at speeds above 30mph
    Jan 2009
    Tallahassee, FL
    Guys I think he needs some new rotors lol
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  15. #15 Re: Vibration when hitting the brakes at speeds above 30mph
    Illinois
    AC delco 80 bucks for pads and rotors.... not to bad I plan on puttin some pics up here in a day or two just been a little busy!
  16. #16 Re: Vibration when hitting the brakes at speeds above 30mph
    re-bed your pads?
    warping rotors is ACTUALLY difficult.
    having the adhesive layer the pad lays down on the rotor come off is easy if you bought cheap pads
  17. #17 Re: Vibration when hitting the brakes at speeds above 30mph
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    vibration on the steering wheel while braking almost always front rotors, vibration on the pedals while braking almost always rear rotors!
  1. noise after hitting pothole
    By kind153 in forum Tires & Wheels
    Last Post: 06-10-2010, 02:39 AM
  2. vibration at highway speeds
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 07:42 PM
  3. Front Upgraded sway bar hitting.....
    By I4NI in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2009, 10:20 AM
  4. Hitting Explosives With A Sledge Hammer
    Last Post: 12-11-2008, 09:27 AM
  5. Car not acellerating past 30mph
    By Bonvoi29 in forum General Tech Discussion
    Last Post: 05-22-2008, 01:38 PM
