Thread: Front Caliper Guide Pins
Results 1 to 8 of 8
  1. #1 Front Caliper Guide Pins
    California
    Replacing Brake pads on my 2006 GT. Just want to know if the front caliper bolts with the rubber bushings on the end go in the top or bottom position?
    I also wanted to know if the disc pads with the wear sensor go to the inside or outside of the caliper?
  2. #2 Re: Front Caliper Guide Pins
    Jul 2010
    Outside ATL
    the guide pins go in the caliper not the bracket (they go in the one with the boot)
    To the other question- inside of rotor (caliper) closest to spring
  3. #3 Re: Front Caliper Guide Pins
    California
    Both the top and bottom bolt holes of the caliper have the boots
  4. #4 Re: Front Caliper Guide Pins
    Jul 2010
    Outside ATL
    do you have a gp? I dont understand, I have two diff size bolts -- long for caliper, short for bracket.
  5. #5 Re: Front Caliper Guide Pins
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    There's too pins that slide into the caliper and the rubber conects them. Then you screw the caliper bolts into the pin when the caliper is installed.
    It doesnt matter which side the pins go in.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  6. #6 Re: Front Caliper Guide Pins
    California
    I know the caliper bolts go into the caliper. The question is that both bolts are different. One is machined on the end for a bushing, the other is not. I want to know if the machined bolt with the bushing goes in the top position on the caliper or if it goes in the bottom.
  7. #7 Re: Front Caliper Guide Pins
    Denver
    Quote Originally Posted by BeachVette6 View Post
    My '98 has identical top and bottom caliper pins (both fit into rubber bushings).
    When you removed them, it's possible that the rubber boot stuck to the pin on one and not the other (this has happened to me before).
    If your bolts are different, it would be simplest to try the non machined one on both top and bottom. The rubber bushing should only allow it to go in either one of the other.
  8. #8 Re: Front Caliper Guide Pins
    Jul 2010
    Outside ATL
    Really it is, your problem will be solved in like a nano with a pic
  1. door hinge / pins
    By hourang in forum General Tech Discussion
    Last Post: 12-11-2010, 12:27 PM
  2. door hinges or pins kit?
    By copperpacecar in forum Visual/Body Modifications
    Last Post: 02-08-2010, 09:53 AM
  3. Front Caliper Rattle
    By tdaye in forum General Tech Discussion
    Last Post: 07-20-2009, 07:14 AM
  4. 2000 Grand Prix Caliper Pins
    By njpampinella in forum Brakes/Suspension/Chassis
    Last Post: 04-18-2009, 11:29 PM
  5. wiring connector pins
    By Toasty in forum General Tech Discussion
    Last Post: 01-20-2008, 01:12 AM
