I just replaced my Rear Struts and Springs, and I have to say it was a sinch! I could do a write up if we need one on here....All i have seen is the quick strut write up. But anyway here are the pics.
Before struts were installed in the rear
After the new struts were installed
It was overall very Easy, the sway bar has a 14mm nut on the back so I can remove the 18mm nut off the sway bar link! The hardest part of all of it was the nuts in the trunk! I used all the original rubber and top mount. I will be replacing the Front Springs, Strut, and top mount in a couple of weeks. Then allignment!!!!!
