Thread: dimensions for trailing arms
Results 1 to 8 of 8
  1. #1 dimensions for trailing arms
    Donating Users
    Idaho Falls
    couple of questions. My trailing arm on one side is bent. Does anyone know the dimensions of said trailing arm. A hole to hole measurement is what I am looking for. What diameter is the bolt that holds the trailing arm on.
    Do they make poly inserts for the bushings on the trailing arm?
    I will just build my own trailing arms, pretty easy to do just need to source some poly bushings or get some rubber replacements
  2. #2 Re: dimensions for trailing arms
    Measure the non bent one?
  3. #3 Re: dimensions for trailing arms
    Pennsylvania
    ... think you can make better ones than UMI or BMR? Anyway, those would be good companies to contact for parts.
  4. #4 Re: dimensions for trailing arms
    Donating Users
    Idaho Falls
    Quote Originally Posted by SlowNA06 View Post
    Actually yes I build custom suspensions on a regular basis. They are for 4x4s but many of the principles interchange. I can also build them much cheaper
    I probably will just measure the non bent one just wondering if anyone had the dimensions then I could just build them and have them on and off in an hour or so
  5. #5 Re: dimensions for trailing arms
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by blazinzuk View Post
    two arms in a hour?? ok
    anyways. No one makes poly replacements. So you will probably have to re use the stock rubber ones.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  6. #6 Re: dimensions for trailing arms
    Donating Users
    Idaho Falls
    Quote Originally Posted by Ridin ON Chrome View Post
    I will probably just measure the hole and use some poly bushings with the right size bolt hole or make a bushing so they fit tight.
    I haven't looked really close at these trailing arms but I have worked on plenty of these types of cars and the arms don't take very long at all to switch, like I said unless there is something weird on this car
  7. #7 Re: dimensions for trailing arms
    These can take many many many hours to get off....
  8. #8 Re: dimensions for trailing arms
    Houston/Baton Rouge
    Yeah, im not saying its impossible. From just looking at them. They dont seem to hard to make, but there's going to be a lot of trail and error.
    With the GMPP bars being like $20. I dont see the point.
    The BMR and UMI ones are great and look great. I just think there overkill..
  1. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  2. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
