Can I adjust the camber myself....or do I have to take it in to a repair shop ?
At the botttom of each strut there are 2 bolts. You need camber bolts to replace the upper bolt on each strut. They are not too expensive, $25 a pair. They allow adjustment of the camber. But then you need an alignment done on a machine.
You just have to slot out the top lower mounting bolt hole.
