Thread: Chassis Vibration Help
Results 21 to 40 of 76
  1. #21 Re: Chassis Vibration Help
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    anything wrong with the rebuilts, or would you rather spend the extra $20 and just get it new? (they both have a lifetime warranty)
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  2. #22 Re: Chassis Vibration Help
    Panama City Beach, FL
    New, all day long. Most of the remans I've had to deal with often have dinged/damaged splines, and I get really pissy when having to file splines to make 'em fit.
  3. #23 Re: Chassis Vibration Help
    Tyler, TX
    sounds good!
  4. #24 Re: Chassis Vibration Help
    Tyler, TX
    Well, the new duralast driver side axle and seal went in today. Job took a total of two hours from putting it on and taking it off the lift. I was taking my time.
    ...surprise, surprise, the vibrations went away! I did get some highway driving in on the test drive, just to make sure too. No leaks with the new seal either! (wahoo!, heard that happens a lot...) I just used the 36mm socket to pound it in. It fit the seal perfectly.
    Hopefully the shop has time to get it on the alignment rack tomorrow
    Well, it rides much better... not quite like a cadillac.... more like a pontiac... smooth, but still bone jarring
    Thanks everyone for all your help!
  5. #25 Re: Chassis Vibration Help
    Hoo-hah.
  6. #26 Re: Chassis Vibration Help
    Tyler, TX
    .... still need to look at the tune though .........does it ever end? ... oh, we're talking about modded cars here ----> NO
  7. #27 Re: Chassis Vibration Help
    No sir, it does not. The '02 has developed a mystery vibration as well, gotta look into it when I head to ATL next weekend. Must mix another drink.
  8. #28 Re: Chassis Vibration Help
    Tyler, TX
    Well.... %$^&(*%$#%#%^& I'm not sure this will ever go away . After a long road trip this weekend, no luggage (weight) or other passengers (900 miles round trip @80-90 MPH averaging~24MPG) the vibrations are still here, and probably more annoying.
    They are much more noticible in the 25-35MPH range though, and sometimes they are there, others they aren't. It doesn't seem to matter if it's hot, cold, or has been driving for 5+ hours on end. Highways speeds is preeety good, not 100% vibration free, but I think I'm being picky with what little is left at highway speeds. The in town vibration got pretty bad this morning though. It does not seem to go increase or decrease with speed or RPM when it's in "vibration operating MPH range" (again ~25-35)
    To top it all off, I have a roadtrip every weekend for the next couple coming up and I have to take the grand prix.
    Any ideas? I haven't noticed any play, anywhere. Could it be the outer CV axle this time? Haven't curb checked anything, so I'm pretty sure the wheels are still balanced from a couple weeks ago.
    Thanks guys!
  9. #29 Re: Chassis Vibration Help
    Doubtful on the outer joint, as I'm assuming you didn't replace only the inner joint, but rather the entire axle assembly. Low speed vibration is almost always tire/wheel related. If you can, get the wheel and tire on a balancer and watch the tread surface as it spins...Check for hop and lateral runout. PS, I've got family in town this week, so I've been scarce, and our board is acting goofy. Hit me on the cell if you need me befo I check in.
  10. #30 Re: Chassis Vibration Help
    Tyler, TX
    right, I replaced the entire CV axle on the driver's side. I was asking if the passenger side CV axle could be an issue.
    I've got road trips this and next weekend... I'm driving down to Orlando for the second one. I'm hoping to have the vibration resolved by then. I've been wondering if it the tire itself as unzip2000 mentioned in post#3, since the tires are balancing out just fine.
    Not sure if I have time today to get it onto the lift/into a shop, definately won't have time the rest of this week or next
  11. #31 Re: Chassis Vibration Help
    Well, remember, tires can balance, despite not being round.
  12. #32 Re: Chassis Vibration Help
    Tyler, TX
    wohooooo!!! Well, at least I know that the right rear had tire hop. The Bridgestone Potenza 960AS Pole Positions will be in tomorrow. Hopefully, I'll have time to get them installed.... and then, hopefully that fixes the problem for good! (wallet is going to hate me though ....)
  13. #33 Re: Chassis Vibration Help
    Tyler, TX
    Ok, finally got back from the tire store. I didn't have time yesterday. I didn't get the Pole Positions because I was able to talk him down on the Bridgestone Potenza G019 Grids by quite a bit. ...not sure if I shoulda done that because I still have traction issues, but I've only put 30 miles on them I'll put 300 on them this weeked and re-asses. The good news is that I get a free 30 day trial with them, so if I'm still unhappy, I can always upgrade
    ...and no, the vibration is not 100% gone...... but I'm hoping that putting some miles on the tires will help.
    I also noticed a "clunk" today when turning the steering wheel to full left lock. In order to re-create it, the car must be in motion and going faster than a crawl. Any ideas?
    THANKS!
  14. #34 Re: Chassis Vibration Help
    Tyler, TX
    yeah, after the long trip. problem is still there. new tires did nothing for it, almost seems worse... despite not being able to balance the old ones.
    I'm sick of looking for this thing, especially since mechanics can't even figure it out!
  15. #35 Re: Chassis Vibration Help
    Quote Originally Posted by 03GTPLE View Post
    THANKS!
    I have an idea you'll be using that 30 day ride guarantee on the G019s... Thay're not one of my favorite BFS products. Did you buy those at Big 10 or Firestone? If you can swing a day to come down we can throw it on the rack and I'll have a look at it and balance the tires properly (since that seems to be impossible for 99% of shops ) and we can shake down the front end in search of the issue. The clunk in the front end almost always is either the rack mount or cradle, either can be easily tightened up. BTW, PM me your # again so I can program it- IIRC you still have a funky # from Colorado, and I'm semi-famous for not answering if I don't recognize a number.
  16. #36 Re: Chassis Vibration Help
    Tyler, TX
    got em at firestone...... I'll be off to Orlando this weekend (gonna see the wife and kid agian!!) Then, next weekend I should be in PCB
    clunk is brand new, never heard that before until now.. this is just depressing.
  17. #37 Re: Chassis Vibration Help
    Rock on, have fun. We'll see ya next weekend.
  18. #38 Re: Chassis Vibration Help
    Tyler, TX
    Well, better news. Just got back from having the alignment done and tires re-balance (good ol' lifetimes are sweet). I didn't get to get out on the open road, but it's much smoother.... as long as I'm off the throttle. Prior to this, it was pretty bad even without being on the throttle.
    So now, I guess the vibration under throttle is either a CV axle, hub, or transmission! Well, 2 out of the 3 on the drivers side were just replaced last month or two and should are still under warranty (lifetime axle, 1 year hub) ...hopefully they went bad, and these bad vibrations will be gone!
  19. #39 Re: Chassis Vibration Help
    Tyler, TX
    Here's a thought. When I replaced the axle, I was able to move around the shaft inside the transmission with my finger (the one next to the seal). Is that supposed to happen, or is it just broken?
    I'm contemplating just going and getting a new hub and axle and throwing those in if I have time this weekend just because they are under warranty and all I need to pay for is a new seal ........ argh. ....simply because I'll throw free parts at it all day (only the driver's side is free for both the hub and axle).
  20. #40 Re: Chassis Vibration Help
    Tyler, TX
    anybody else have any thoughts between 02WS6TA and myself?
    Thanks!
  1. bad vibration under wot
    By shawnheck03gtp in forum General Tech Discussion
    Last Post: 10-08-2009, 09:03 PM
  2. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
  3. Building a 93 pro street grand prix n have a chassis ?
    By lukeeep in forum Brakes/Suspension/Chassis
    Last Post: 03-28-2009, 08:01 PM
  4. I need a body/chassis
    By YoungGTP in forum Visual/Body Modifications
    Last Post: 09-05-2008, 02:38 PM
  5. Engine Ground to Chassis wire
    By AlmightyBirdman in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2008, 07:39 AM
