Thread: aluminum subframe
Results 1 to 20 of 27
  1. #1 aluminum subframe
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    Has anyone heard or has done this to their car. Aluminum subframe off of a 04 impala on the grandprixs. I heard its about a 25-35 lb drop in wieght alone and is suspost to be stronger/stiffer also. It seems like a good idea to help everyone and take some lbs off of these cars and help them on the street and track.
  2. #2 Re: aluminum subframe
    04+ GPs have them too
  3. #3 Re: aluminum subframe
    marshalltown, iowa
    I was told that they do also. But I wasnt for sure on those. But would either one of the aluminum subframes work on the 98-03 gps? Would they bolt right up or needed modded to work?
  4. #4 Re: aluminum subframe
    you dont want to remove weight from the font end. we have enough traction issues as it is.
    also, the aluminum subframe is known to crack.
  5. #5 Re: aluminum subframe
    marshalltown, iowa
    Ok I didnt know about all that. I mite just forget about that then. I would like to take some wieght off of the car though. Would do you guys say to save some lbs?
  6. #6 Re: aluminum subframe
    go on a diet.
    really, there arent a ton of places you can remove weight without losing its 'streetability'.
  7. #7 Re: aluminum subframe
    Jan 1970
    Maquoketa, Iowa
    They are a pretty significant weight savings and if they were known to crack they wouldn't be on 01+ impalas and 04+ gp's. If you can get it for cheap and don't mind the hassle of swapping them out, then i'd be all for it.
  8. #8 Re: aluminum subframe
    marshalltown, iowa
    I dont wieght all that much. Im 6'1" and 200 lbs. Thats not to bad.
    I heard of taking out the rear bumper bracket and the sound deading under the carpet. But i dont know about all that. But the aluminum subframe would be a great wieght reduction and I heard they crack. But the monte ss hase the same motor and trans as we do. But the have the aluminum frame and I wouldnt see how they would crack. I know these cars have tracion probs.
  9. #9 Re: aluminum subframe
    Been there done that. I hear that only under a ton of HP mods they crack. Know a lot of locals with Stage 3 setups that never had issues. Not sure what it takes to crack one.
  10. #10 Re: aluminum subframe
    they do BEND.
    I have one here I can take pictures of to show you.
  11. #11 Re: aluminum subframe
    marshalltown, iowa
    Yea if you would take some pics so I could see it. How would you be able to bend one of those?
  12. #12 Re: aluminum subframe
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Its 20-21lbs lighter and you will need the bolts and bushings
    Front Upper mounts #10402880 (x2)
    Frontt lower mounts #10402882 (x2)
    Rear upper mounts #10402881 (x2)
    Rear lower mounts #10402883 (x2)
    Front bolts #10403403 (x2)
    Rear bolts #10410940 (x2)
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  13. #13 Re: aluminum subframe
    marshalltown, iowa
    I didnt know that you would have to have everyhitng like that for the swap. Is it really worth the 20lb diff in wieght?
  14. #14 Re: aluminum subframe
    You'd need an alignment as well.
    Still want a picture?
  15. #15 Re: aluminum subframe
    marshalltown, iowa
    this thing is sounding more and more of a pain to do then I want. I just spent 200 on a alignment at the dealer. I know I got ripped off
  16. #16 Re: aluminum subframe
    yuppers, $80-100 around here.
  17. #17 Re: aluminum subframe
    marshalltown, iowa
    Damn I must be in the wrong line of work. lol
    But anyone have any ideas to shed some wieght of these cars?
  18. #18 Re: aluminum subframe
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by sdenton8 View Post
    What year? there is a lot of onstar crap you could take out
  19. #19 Re: aluminum subframe
    marshalltown, iowa
    I have a 2000 gtp. I dont think I have onstar??? Maybe I do and dont know it. But I doubt I do. Anything else I could take off?
  20. #20 Re: aluminum subframe
    in the trunk in the rear left corner there would be a onstar box if you had it.
  1. subframe swap
    By GTPJAY in forum Brakes/Suspension/Chassis
    Last Post: 01-24-2010, 04:21 PM
  2. Subframe Bolts
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 04:04 PM
