Thread: Replaced front sway bar, new noise
Results 1 to 4 of 4
  1. #1 Replaced front sway bar, new noise
    SE Level Member the1euge's Avatar
    Apr 2008
    Pittsburgh, Pa
    I just replaced my front sway bar with a upgraded gmpp one because my stock one was broken completely and making a terrible banging noise, and now im dealing with another brand new suspension/front end noise. Now there is a thumping noise coming from what i believe is the drivers front. it sounds like a rotational noise because it follows the speed of the wheel ie: thumps faster or slower depending on my speed from 5-50ish. its not a grinding noise, and it only happens when driving in a straight line. goes away when turning left or right.
    i made sure all the bolts i accessed to install the sway bar were tight today, but still making this thumping noise.. Any ideas what this might be?
  2. #2 Re: Replaced front sway bar, new noise
    Donating User Odi's Avatar
    Chicago South Suburbs
    did you check your wheel bearings?
  3. #3 Re: Replaced front sway bar, new noise
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Did you install the bar upside down? You need to if not. It's probably hitting the downpipe.
  4. #4 Re: Replaced front sway bar, new noise
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by VinnieGTP View Post
    What I'm thinking as well.
    Easy fix, just pull it back out and flip it the other way.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. front sway bar
    By Toasty in forum General Tech Discussion
    Last Post: 03-23-2013, 12:34 PM
  2. Null
    By kswissbob in forum General Tech Discussion
    Last Post: 01-04-2010, 08:54 PM
  3. Cracked Front Sway Bar
    By hacket in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2009, 12:50 PM
