Thread: "clunk" sound on acceleration
Results 1 to 14 of 14
  1. #1 "clunk" sound on acceleration
    Canada
    Hi guys do you know of a common problem with a clunk sound on acceleration (slow or moderate) ? Can go days without hearing it but always seems worst when its raining or wet outside (lol go figure) I checked A frame bushings and they seem fine?? any ideas ? Its a 2005 GT......thx in advance for any ideas.
  2. #2 Re: "clunk" sound on acceleration
    Charles City, IA
    Check the cradle bolts. Also could be a worn cv shaft.
    SMGPFC Two Nipple General
  3. #3 Re: "clunk" sound on acceleration
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    also check sway bar links. Took mine to the dealer for a similar issue and some others (i know, i know, but its under warranty so wth) for some other stuff and that's what they told me. If you're getting a clunk from coasting to acceleration, flipping the dogbone bushings will help with that.
    my $.02
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  4. #4 Re: "clunk" sound on acceleration
    Canada
    thx guys i'll have a look at sway bar links......what do u mean by dogbone bushings? is this the "A frame" bushings or the bushing similiar to a hockey puck shape on the main front frame?
  5. #5 Re: "clunk" sound on acceleration
    Jun 2010
    Christiansburg, VA
  6. #6 Re: "clunk" sound on acceleration
    Oct 2008
    K-W, Ontario, Canada
    This may or may not be, but my '08 made a clunking noise upon acceleration and occasionally on braking. I realized that it was happening on a full tank of gas, one of my straps had loosened slightly and the whole tank would move when it was full.
    Have a look, let us know what you find.
  7. #7 Re: "clunk" sound on acceleration
    GT Level Member scoobyydooooooo's Avatar
    Houston, Texas
    So what was the outcome of this issue, I have the exact same issue,, my car is 2005 GTP.. loud clunk or pop when accelerating, and sometimes when going in reverse... mainly on driver side..
    05 GTP, Inferno Appearance package, SD Headers, 2.9 Pulley, 104 autolites, Wizaired CAI, 180* T-stat, SPO tips, Nav sytem, polymounts, S2IC, XPCAM, much more to come
  8. #8 Re: "clunk" sound on acceleration
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    same problem with my car I have a 02 gtp and it the torque strut bar bushing!! Aka dog bone!! Mine were messed up so I ordered 2 poly bushings and it helped...
  9. #9 Re: "clunk" sound on acceleration
    Houston, Texas
    Timmy, thanks,,, I will order mine now,, Well, are these the polymounts, the red looking squares that you are speaking about? thanks again.
  10. #10 Re: "clunk" sound on acceleration
    Jul 2010
    marrero louisiana
    yea and when I ordered them I went ahead and got the two round ones that are one the other side of the dog bone!! And make sure that the two arms that run from your rad support 2 where your struts mount under the hood that all bolts are tight in them also!!! Any more questions just let me know
  11. #11 Re: "clunk" sound on acceleration
    Houston, Texas
    Nice, Im going to order the ones from intence, seems that everyone preferes these as the are not as loud and rough as the ZZP ones. thanks again.. I assume I will need to take these dog bones and supports completly off my car, does the engine need to be supported? or just do one at a time? Thanks again..
  12. #12 Re: "clunk" sound on acceleration
    Jul 2010
    marrero louisiana
    one at a time works great!! Np
  13. #13 Re: "clunk" sound on acceleration
    Charles City, IA
    You can take them both off at once.
  14. #14 Re: "clunk" sound on acceleration
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    common issue with the 04+... its the intermediate steering shaft... the only place you can buy is from the dealer... search intermediate shaft in the forum and read different explanations and see if that sounds like your problem...
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "CLUNK" suspension noise when i step on it?
    By whitelightning in forum General Tech Discussion
    Last Post: 05-29-2010, 05:51 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  4. "Clunk" on initial rolloff
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2008, 05:07 PM
