Thread: GMPP Sway bar bushings into stock brackets?
Results 1 to 7 of 7
  1. #1 GMPP Sway bar bushings into stock brackets?
    Jan 2009
    MN
    Just got the GMPP sway bars from Summit and they came with new bushings of course because the sway bars are larger than stock. I did not get any new brackets that hold the bushings to the body. Will the new bushings fit? I'm assuming the new bushings are the same size just with a larger hole in them. thanks!
    Sorry for the n00b question.
  2. #2 Re: GMPP Sway bar bushings into stock brackets?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    Quote Originally Posted by JBONE View Post
    yes the new bushings go into the original brackets. bolt everything together and your done easy as 1 2 3
  3. #3 Re: GMPP Sway bar bushings into stock brackets?
    Jan 2009
    MN
    Thanks a lot, just wanted to double check
  4. #4 Re: GMPP Sway bar bushings into stock brackets?
    IN
    hey, i know this was awhile ago but i'm having a horrible time getting my brackets to screw all the way down.. i'm a little past half way and have given up trying.. is it supposta be this hard?????
    thanks
  5. #5 Re: GMPP Sway bar bushings into stock brackets?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    yes, there bigger. There supposed to be tight and you need to tq them down too
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  6. #6 Re: GMPP Sway bar bushings into stock brackets?
    IN
    crap kk, just got an extension for my wrench so i'll try it. looks like i got some work ahead..
  7. #7 Re: GMPP Sway bar bushings into stock brackets?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    should have taken a wire whel and cleaned off some of the corrosion from the brackets first.
  1. GMPP Sway bar frame bushings???
    By Toasty in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2009, 02:52 PM
  2. Sway bar bushings
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 09-13-2008, 03:47 PM
  3. GMPP Sway Bar
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2008, 09:07 AM
  4. GMPP strut bars and donrome brackets
    By IndeedSS in forum Brakes/Suspension/Chassis
    Last Post: 01-26-2008, 08:32 PM
