Thread: freshen up suspension
Results 1 to 8 of 8
  1. #1 freshen up suspension
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    hey all, i plan on getting gr-2 and vogtlands, but what other suspension components do i need? i thought about getting bigger sway bars, but im more worried about ball joints and bushings. which ones need to be replaced around 100k miles? i hate that stock doesnt have grease points, and car is feeling like its loosening up nowadays. i prefer poly bushings!! anyone rocking prothanes or energy suspension stuff?
  2. #2 Re: freshen up suspension
    Donating User Odi's Avatar
    Chicago South Suburbs
    im switching my swaybars and will order a set of energy suspension brackets and bushings (gotta measure the bar first, couldnt find any data on SLP SB's). I know people who run Energy Suspension stuff and theyre pretty happy.
    Get better trailing arms, stock ones are garbage.
  3. #3 Re: freshen up suspension
    trailing arms are the only things that is going to make a big difference besides lowering the car.
  4. #4 Re: freshen up suspension
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    sway bars totally made a difference. i did them one at a time. plus that rear bar goes in in like 12mins flat.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  5. #5 Re: freshen up suspension
    Jan 2009
    san diego
    these are great, but what about stiffer ball joints, if i have to replace them anyways with 100k miles on them? and other bushings? just get better stuff for sway bars and new trailing arms...sounds like a plan then
  6. #6 Re: freshen up suspension
    Jan 2009
    san diego
    i am having the hardest time trying to find dogbone inserts for the small end now. i found the giant blocks of poly, but cant find the small end inserts now...
  7. #7 Re: freshen up suspension
  8. #8 Re: freshen up suspension
    Jan 2009
    san diego
    awesome! thats the ones. thanks guys! yeah i might be doing sways and trailing arms, but for now i just need motor mounts (getting really mushy on shifts on me) and shocks/springs. i will get sway bars and the fixins later though.
  1. Re-Doing Suspension
    By GPBoy00 in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2009, 02:27 PM
  2. Suspension HELP!!!
    By gleivas in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 11:05 PM
  3. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  4. Suspension
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2009, 08:30 AM
  5. Suspension Help
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2008, 08:41 PM
