Thread: Want to lower your car? Look in here!!
Page 29 of 29 FirstFirst ... 19272829
Results 561 to 575 of 575
  1. #561 Re: Want to lower your car? Look in here!!
    Nov 2014
    BFE,Ohio
    has anyone tired out the new style wbs springs with only a 1" rear drop i was going to use them with agx struts
    or intesnse coil over kit
  2. #562 Re: Want to lower your car? Look in here!!
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    FYI, I'm selling the spacers with free shipping until January 2nd. So that's $47 instead of $53 shipped.
  3. #563 Re: Want to lower your car? Look in here!!
    GT Level Member mikejohnlewis's Avatar
    Jul 2014
    Manchester, Iowa
    are there any other DNA soring pics and opinions, my laptop will load all of the pictures but the ones I want to load.
    1997 Grand Prix GT 3.8(SOLD)
    2002 40th Anniversary Coupe GT (SOLD)
    2000 Daytona Coupe GTP (Summer Car)
    2011 Ram 1500 (daily)
  4. #564 Re: Want to lower your car? Look in here!!
    Aug 2013
    McDonald PA
    Quote Originally Posted by mikejohnlewis View Post
    Comparable to sscs I think. I know some people had to cut coils off on the rear
  5. #565 Re: Want to lower your car? Look in here!!
  6. #566 Re: Want to lower your car? Look in here!!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    If your going with canuck springs do you need to install a camber kit?
    Sent from my LG-H901 using Tapatalk
  7. #567 Re: Want to lower your car? Look in here!!
    if necessary you can slot the upper mounting bolt hole on the lower strut mounts. that way you can adjust the hub for camber when doing an alignment. it's really the best way to solve it instead of using camber bolts.
  8. #568 Re: Want to lower your car? Look in here!!
    Dec 2012
    troll land
    Another option is camber spacers
  9. #569 Re: Want to lower your car? Look in here!!
    SE Level Member onklp's Avatar
    Apr 2016
    Canada
    hi guys i have question i have 07 gp and want to buy lowering springs can i use coils form 03+ gp or impala 03+?
  10. #570 Re: Want to lower your car? Look in here!!
    Dec 2012
    troll land
    Yes
  11. #571 Re: Want to lower your car? Look in here!!
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    If I went with Moog Police/Taxi quickstrut (I assume it's FE4 or is 9C1 package different) would I get any height change? O don't want anything too stiff, just something better than my FE2 with hopefully better gasing. Part #ST8558
  12. #572 Re: Want to lower your car? Look in here!!
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    What year? I believe the FE3 and FE4 raise '03 down cars noticeably. If you have an 04+ I don't see the ears for the sway (could just be a stock photo), so your suspension has to be set up for that.
  13. #573 Re: Want to lower your car? Look in here!!
    Dec 2013
    NJ
    04 but I swapped to the older LCAs so I could run the larger sway bar.
  14. #574 Re: Want to lower your car? Look in here!!
    Nov 2018
    OH
    Ok guys, I am newer to this forum, but not the car scene. This is my second GXP and I am replacing struts/springs. I would like to go with a 1.5” drop but I can find a spring anywhere. I’ve been searching Canuck and eibach but no success. Is there something I’m missing? It’s an 06 GXP BTW.
    TIA,
    Chris
  15. #575 Re: Want to lower your car? Look in here!!
    Jul 2010
    Coquitlam,BC,Canada
    They claim 1.8/1.6 for the 97-03, and I ended up with 1.1875/.625 when I used their springs.
    They claim 2.5/2.0 for the GXP and 1.7/1.7 for non GXP. Why not go with the non GXP springs?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
