Thread: Want to lower your car? Look in here!!
Page 28 of 29 FirstFirst ... 1826272829 LastLast
Results 541 to 560 of 575
  1. #541 Re: Want to lower your car? Look in here!!
    See the springs on the "right" closer to the opened box, those are rear springs. They are wider and less "coils".
    The two that are off to the left are front springs.
  2. #542 Re: Want to lower your car? Look in here!!
    Longer springs = rears
    Unless you got a incomplete set
    04 Comp G.
  3. #543 Re: Want to lower your car? Look in here!!
    GT Level Member atj8's Avatar
    Midwest
    ok thanks guys! yea idk i bought it off the forums a while ago...got a good deal on them.
  4. #544 Re: Want to lower your car? Look in here!!
    Post a picture we can probably tell you just to make sure
    04 Comp G.
  5. #545 Re: Want to lower your car? Look in here!!
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Makes me want to finish my other set of coilovers and put them on the '99
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  6. #546 Re: Want to lower your car? Look in here!!
    needs more camber. it's got some mexi-poke. and that stretch/tire size is totally unnecessary for the ride height. it needs to be lower for those wheels/tires. it's not even tucking tire.
  7. #547 Re: Want to lower your car? Look in here!!
    Bio has spoken!
    04 Comp G.
  8. #548 Re: Want to lower your car? Look in here!!
    well, get serious for a second. when you're going for that look, why would you half ass it? it ends up looking stupid then.
  9. #549 Re: Want to lower your car? Look in here!!
    It's got some stupid 1in thick spacers on there. Because likely the bolt pattern is different.
  10. #550 Re: Want to lower your car? Look in here!!
    Jan 2009
    Tallahassee, FL
    More camber and low.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  11. #551 Re: Want to lower your car? Look in here!!
    Aug 2013
    McDonald PA
    Are 97-03 struts the same as 04-08 in the rear? It's the fronts that are diff correct??
  12. #552 Re: Want to lower your car? Look in here!!
    Oct 2011
    Toledo, OH
    Only the 04 & 05 are definitely different. 06+ might have either kind of fronts. You'll have to go look.
    7"
  13. #553 Re: Want to lower your car? Look in here!!
    Aug 2013
    McDonald PA
    Quote Originally Posted by industrialfish View Post
    I would but I don't know the difference in them
  14. #554 Re: Want to lower your car? Look in here!!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Compare the part numbers on RA for the rear on your year vs a 97-03 car.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  15. #555 Re: Want to lower your car? Look in here!!
    Aug 2013
    McDonald PA
    Ohhh good call
  16. #556 Re: Want to lower your car? Look in here!!
    Oct 2011
    Toledo, OH
    That doesn't work, because some 06+ have either style. Go look at your car, if the sway bar connects to the strut you need the 04/05 specific style. If the sway bar connects to the Lower Control Arm you can use any front strut.
    Edit: doh you said rear.
    7"
  17. #557 Re: Want to lower your car? Look in here!!
    The rears are the same. The fronts are where it gets interesting.
    04 Comp G.
  18. #558 Re: Want to lower your car? Look in here!!
    Go look at your fronts struts and see where the endlinks connect. It they connect to the strut then that'll be the 04 style if they connect from the control arm to sway bar that'll be the 97-03 style.
    04 Comp G.
  19. #559 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    Is there another place to get the anti-pogo washers other than Wbodystore? They want $15 per pair, which is ok, but then another $20 to ship them. If I wanted to get reamed that bad I'd walk through SF in assless chaps.
  20. #560 Re: Want to lower your car? Look in here!!
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
