Thread: My Caliper iS StuCK!! Help its urgent.
Results 1 to 3 of 3
  1. #1 My Caliper iS StuCK!! Help its urgent.
    chicago
    Any methods on how I can get this caliper pin out of the bracket and caliper???
  2. #2 Re: My Caliper iS StuCK!! Help its urgent.
    Wichita, KS
    Front...or rear here?
    ~F~
  3. #3 Re: My Caliper iS StuCK!! Help its urgent.
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    You're talking about the caliper bolt not the caliper piston right?
    Did you loosen the bolt already or is the bolt unable to turn? I had both when I did a friend's brakes, breaker bar and hammer (or wrench and a pipe) helped loosen it with pb blaster. If its out and you keep turning it then a flat screwdriver and a hammer helped me knock it straight out.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  1. Stuck Caliper bolts
    By tjwenger in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2010, 08:24 PM
  2. urgent is my tranny hooped
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2010, 11:41 PM
  3. Help urgent!!! No start (Park Avenue)
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 11-01-2008, 07:39 PM
  4. urgent dead car
    By Sunstone in forum General Tech Discussion
    Last Post: 09-07-2008, 12:22 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
