Thread: lowering springs help
Results 1 to 12 of 12
  1. #1 lowering springs help
    College Station, TX
    Ok im about to get some springs but i just dont know what to get. ive been lookin at eibach, sprint or vogtland springs so far and they all seem like great springs. so i was just seein if anyone has any input. i do want a pretty good drop atleast like 1.5"
  2. #2 Re: lowering springs help
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I'm "pondering" the same question but I was told I would have to "shim" engine!? Not so sure what thats about so I stayed clear. Would be nice to drop some and get rid of the damn sag in the rear during acc. Let me know if you do get some and how they turn out.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  3. #3 Re: lowering springs help
    unless youre going to get some good struts (AGX's) with eibachs then forget about it. my ride is crappy as hell. i would LOVE to upgrade to some vogtland/AGX's all around the car.
    as far as the "shimming"...its because the lowering offsets the geometry of the tranny, therefore causing your axels to be at the wrong angle. this causes acceleration vibration. solved by a) putting plates in the lower motor mounts to raise the engine up or b) shortening your dogbones. i have shortened dogbones and it has worked pretty well for me. this also stresses your lower mounts more because of pulling the engine forward so far. option a is the best way to solve it, but it also may mean you will never run an intercooler.
    if you lower and your wheels rub, use a hammer.
    that is my advice to you..
  4. #4 Re: lowering springs help
    chicago
    i have ssc springs still on stock struts. my ride is not bad at all. i'm still little scare of getting 18x9 bullitts
  5. #5 Re: lowering springs help
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Just be sure to get the +36mm offset ones and roll your fenders.
    I have a write-up on here to do it.
    It's exactly what I run.
  6. #6 Re: lowering springs help
    College Station, TX
    so should i not even bother putting in springs unless i get new struts, because i do plan on putting in camber adjustments so it will go back to the stock alignment once lowered. but it dont wanna put in springs and then find out i jus ended up doin more damage than good.
  7. #7 Re: lowering springs help
    lowering springs destroy stock struts. you need to prepare accordingly with struts made for lowering vehicles.
  8. #8 Re: lowering springs help
    College Station, TX
    ok well i think im gunna get the vogtland springs with the kyb gr2 struts other than the agx ones (too much $$$)..hows that sound? will the gr2's be sufficient enough for a 1.5" drop?
  9. #9 Re: lowering springs help
    Las Cruces, NM
  10. #10 Re: lowering springs help
    St. Louis Mo.
    My old setup was the KYB GR-2's and SSC Gen II springs. It lowered nicely, but it didnt slam it like others do. The only complaint I had is that GR-2's road to harsh for me. I am picking this weekend my new AGX struts and SSC Gen II's from a guy down in Louisville.
    I had a little vibration at 60mph but I never used shims or shortened dogbones. My summer rims are 18x8.5. They should clear ok once the springs "settle." Only time will tell
    James Shafer
    St. Louis MO
  11. #11 Re: lowering springs help
    College Station, TX
    alright sweet, thanks alot yall
  12. #12 Re: lowering springs help
    i have gr2s and they ride crappy. but they are also shot from running eibachs.
    i would kill for a vogtland and agx setup.
  1. springs
    By MTXGTP in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2009, 11:11 AM
  2. SSC springs
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 11-16-2008, 08:47 PM
