Thread: using up my back tires
Results 1 to 20 of 22
  1. #1 using up my back tires
    Feb 2010
    NY
    GP GT 07
    i have changed my tires a couple of month ago cause they were used up from unevenly in the back. i have noticed that the whole back tires are tilted weirdly. this way "/--\" so i had them fixed and changed the tires now i see the same tilt again ?!?!?!? any ideas ?? HELP PLEASE...
  2. #2 Re: using up my back tires
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    Your alignment is off, too much negative camber, get it fixed.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  3. #3 Re: using up my back tires
    Feb 2010
    NY
    i already did that when i changed the tires, and they went back to like they were before.
    something is affecting the allignment ...
  4. #4 Re: using up my back tires
    The back tires on these cars are supposed to have 0.0 camber. What you are describing about the tires leaning in is negative camber. The lateral links would be adjusted to fix this, some places only check toe during alignment because camber is usually fixed. I assume you have checked for correct tire pressures.
    The only other area I can think of that would cause this is lowered or shortened springs/struts or a problem with them because that's the only other part that effects camber.
  5. #5 Re: using up my back tires
    May 2008
    staten island,NY
    you took the car for an alignment, and they charged you money....did they install camber bolts or elongate the holes in the strut mounts? if not youve been beat because you need either one of those things to adjust the camber
  6. #6 Re: using up my back tires
    Feb 2010
    NY
    well i guess i have been beat, the dude is an A$$ he wants to chage the whole back suspension(struts springs ....) so that he wont bother to figure out anything and he will make more money with the parts and labour ?!?!?!?!
    i was kinda hesitant to go back and i neede to ask you guys before i go back(fool me once shame on you fool me twice shame on me)
    i feel that i am gonna go back he will charge me 50 $ for each side and i will have the same problem again. knowing that i am using up the new tires.
  7. #7 Re: using up my back tires
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    this seams like an easy fix. go to someone that you can trust to do a good job instead. just saying
    silver 2003 Grand Prix GT List is on it's way to be updated
  8. #8 Re: using up my back tires
    Feb 2010
    NY
    kjohnson:
    thats the hardest part, unfortunatly not alot of people do what they are supposed to ... this is why car forums are very poppular cause honest experts take the time to help out people like me
  9. #9 Re: using up my back tires
    Nov 2008
    thats very true. mabe find some place that offers a guarantee on their work. idk if you can find a place like that but its worth a shot. I really think they are right though with the alignment thing. makes sence to me anyhow
  10. #10 Re: using up my back tires
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    put new rear struts on it the rear prolly sagging causing the allighment too chew up the tires thats why u your tires have too much negative camber the rear adjustment is only for toe, not camber! easier fix is to ream out the top bolt whole on the strut (spindle bolt) then pull tire out and put bolt back in tighten her down problem fixed !
  11. #11 Re: using up my back tires
    ^^agreed
    Having taken a second look at the lateral links only one is adjustable, negative camber in the back wheels is caused by a strut issue.
  12. #12 Re: using up my back tires
    Feb 2010
    NY
    i have ordered 2 rear strut entire assemblies from Monroe(Quick-Strut®) like this he wont need to use alot of his skills. he will have take out the original and put it the new assembly whole. plus its a different dude. i will tell you guys what will come out of this.
  13. #13 Re: using up my back tires
    iowa
    You still should have the alignment check after changing the rear struts. Also make them give you a copy of the alignment specs after they align it so you can see whats been done.
  14. #14 Re: using up my back tires
    lower the car and run the negative camber to help your hellaflush look.
  15. #15 Re: using up my back tires
    Feb 2010
    ohio
    ^^roflmao
  16. #16 Re: using up my back tires
    May 2008
    staten island,NY
    i love that look on the bmw's
  17. #17 Re: using up my back tires
    Feb 2010
    ohio
    ^thats a lexus
  18. #18 Re: using up my back tires
    May 2008
    staten island,NY
    clearly, im saying the bmws come factory with the negative camber and technically its a toyota aristo, imported as a lexus gs
  19. #19 Re: using up my back tires
    Feb 2010
    ohio
    my bad just thought you were thinkin it was a bmw
  20. #20 Re: using up my back tires
    GTX Level Member Deimos's Avatar
    iowa
    Cam bolt on the rear should be a Moog number K5330. It's cheaper if ou buy them and put them in and then tell the alignment shop its got them because they can't charge you for it. The plastic opening is installed straight up and in line with the notch on the head of the bolt.
  1. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
  2. Back Again
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 11:10 PM
  3. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  4. Back on here.
    By Dohner in forum Off Topic Discussion
    Last Post: 05-12-2009, 08:49 PM
  5. Im back :D
    By Ninjo in forum Introductions/Noob Questions
    Last Post: 10-28-2008, 05:09 AM
