Thread: C/5 F body upgrade
Results 1 to 7 of 7
  1. #1 C/5 F body upgrade
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    I was going to run to the j-yard and pick up the caliper brackets, so I can do the C5/ F body brake upgrade. Does it matter what year camaro firebird? I do not have any 98-02 in my local yard, just a bunch of older v6 f bodys can I use those?
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  2. #2 Re: C/5 F body upgrade
    Portland Oregon
    You need brackets from a V8 98-02 model year.
  3. #3 Re: C/5 F body upgrade
    Nov 2009
    Portage, IN
    Ok thank you very much
  4. #4 Re: C/5 F body upgrade
    Banned - Busted For Scamming
    Feb 2009
    Its any 98-02, they got the same brakes. Doe NOT have to be the ls1
  5. #5 Re: C/5 F body upgrade
    Nov 2009
    Portage, IN
    Yeah I just looked on ebay, craigslist, no such luck I will check the junkyard again. So I plan on getting the caliper brackets from the junkyard, and the calipers I may want to switch to the c5 calipers. Got nice rotors, and put slap everything together
  6. #6 Re: C/5 F body upgrade
    GT Level Member sic6's Avatar
    san marcos, tx
    I think you could also use the 06 and up calipers from the monte carlo as they are also a dual piston design.
  7. #7 Re: C/5 F body upgrade
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Yup, V6s have the same brakes
    Quote Originally Posted by sic6 View Post
    Yes you can, but there different then the F-body.
    You will need 06 monte/impala pads and rotors.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Major loss to the G-body/W-body community
    By Sabrewings in forum Off Topic Discussion
    Last Post: 05-21-2008, 03:47 PM
  2. First upgrade...
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-13-2008, 11:13 AM
