Thread: low brake pedal
Results 1 to 3 of 3
  1. #1 low brake pedal
    Nov 2009
    london
    My brake pedal is virtually on the floor to stop. I had my front pass side wheel bearing fixed and after this my brake pedal collapsed. Maybe no link to the wheel bearing fix. But now my master cylinder was changed and no change and now they want to change the expensive ABS module. That didn't make a lot of sense to me because how would that prevent the fluid from passing through. I was wondering if all it needed was a brake pedal adjustment?? Thax in advance to anyone who can answer this. Confused!!
  2. #2 Re: low brake pedal
    Banned - Busted For Scamming
    Feb 2009
    How are your pads? Also take the damn thing back to them and tell them if they dont properly bleed it out you will sue them. That is all.
  3. #3 Re: low brake pedal
    Jan 2009
    Tallahassee, FL
    I wonder if they messed up your brake line or took it off while doing the hub. If so then they may not have rebled the brakes. How does your brake fluid level look?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. Brake Pedal Positioning Sensor
    By DrDino in forum Introductions/Noob Questions
    Last Post: 01-21-2011, 12:38 AM
  2. Pedal Swap
    By Stpman in forum General Tech Discussion
    Last Post: 08-15-2009, 09:09 PM
  3. sticky gas pedal
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 05:00 PM
  4. Gas Pedal Sticking
    By J_Man55 in forum General Tech Discussion
    Last Post: 06-29-2008, 09:53 PM
  5. stickey gas pedal
    By SnMman in forum General Tech Discussion
    Last Post: 06-11-2008, 03:56 AM
