View Poll Results: Should I get a STB or trailing arms?
Voters
16. You may not vote on this poll
  • Strut tower brace (GMPP or ZZP versions)
    7 43.75%
  • Trailing Arms (Likely from W-body store)
    9 56.25%
Thread: basic suspension upgrades
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: basic suspension upgrades
    They're stamped steel and they rust anyways.
    For the STB to be as effective as possible, they have to attach to the strut tower mounts like ZZ Performance but have a much strong connection between the tower mounts and the cross beam. Also, crossbeam has to have no bends in it for it to be most effective as possible.
    None of the ones I've seen do that so I'd skip on that.
  2. #22 Re: basic suspension upgrades
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    You want to get the body stiff so i would start with front and rear STB. This will help. Followed by rear sway then other stuff.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #23 Re: basic suspension upgrades
    Quote Originally Posted by BlownBigBlock View Post
    Ok, I selected STB's, but only if your existing trailing arms are not rusted to the point that the strength of them is compromised. Buying new trailing arms would only be for piece of mind unless like I said, they are extremely rusted.
    i suppose you have never seen how easily those flex and bend. hard cornering will bend them.
  4. #24 Re: basic suspension upgrades
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Hard cornering can bend anything if the strength of said part is compromised. I'm just saying why replace it just to replace it.
    If the trailing arms in question look like they need replacing by all means do that first, but the OP doesn't say anything about their current condition.
  5. #25 Re: basic suspension upgrades
    because the trailing arms will do more good than STBs will as far as tightening up the suspension. that is what he is going for.
  6. #26 Re: basic suspension upgrades
    Feb 2008
    Trailing arms, then a rear STB, then the front STB. The GMPP STB's aren't very effective unless you plan on getting an adapter plate so they attach to the strut mount itself.
  7. #27 Re: basic suspension upgrades
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    rear end needs more help than the front. the car will understeer no matter what, these cars have not so great weight distribution, plus FWD...go with the trailing arms. and rear sway bar.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  8. #28 Re: basic suspension upgrades
    Apr 2009
    Georgia
    yeah stock ones are junk! BMR makes an awesome set...expensive tho
  9. #29 Re: basic suspension upgrades
    SE Level Member Cbierniat24's Avatar
    Mi
    Anyone have experience or opinions with this kit?
    GM Parts Direct: Your direct source for Genuine GM Parts
  10. #30 Re: basic suspension upgrades
    Its worth getting.
    But the tower bar brace is pretty useless.
    Just get the sway bars and the trailing arms.
  11. #31 Re: basic suspension upgrades
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    I'm a cheap ass and bought my front STB at the GM dealer for like $12 new with hardware and I noticed a difference as soon as I pulled out of the driveway. You can't beat the price unless you find one on a Buick GS or 9C1 impaler in the yard. Just a good cheap mod IMO.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  12. #32 Re: basic suspension upgrades
    Its worth getting.
    Quote Originally Posted by alkygto View Post
    do the above and you'll notice an even bigger difference
  13. #33 Re: basic suspension upgrades
    Apr 2009
    stockton ca
    This reminds me i still have to install my frnt stb
  1. Basic ?? 3.4
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2012, 08:25 AM
  2. Need Suspension upgrades
    By Luda in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2010, 09:17 PM
  3. 1995 GP suspension upgrades?
    By mikefeelsgood in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2009, 04:50 PM
  4. I can't find suspension upgrades for my 04 GT
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 08-07-2009, 05:06 PM
  5. Basic Mod Preference
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 06:41 PM
