I just need a little help, I have a 2001 GTP 90,000 miles, The front end is way out of alignment, and has caused extreme wear on both front tires. Both tires are down to the cords on the inside of the tires center tread and outer tread wear is normal.. Outer Tie rods were repaced about a year ago and the car never got an alignment. There is some grease on the inside of the passenger side rim as well. The car has a good amount of road noise I assume due to the tires , I am going to be putting on 4 new Monroe-Quick Struts in a month or so. I will be switching to my set of Blizzak snow tires for the winter. I know after changing the struts and springs I will need an alignment, does any one have any other suggestions on other possible repairs I should make prior to getting the vehile aligned. Also should I have a 2 wheel or 4 wheel alignment done to the vehicle. I will be getting a new set of summer tires in the spring, and with the winter tires there is a lot of road noise anyway is there any thing I could do to check wheel hubs, cv joint, control arms or any other suspension parts. Car suspension is bone stock other then power slot brakes and hawk pads. Which by the way I would not reccomend very loud combination under moderate to heavy breaking. Anyones imput would be awesome. Thanks!!!
