Thread: ABS problem
Results 1 to 9 of 9
  1. #1 ABS problem
    SE Level Member fierogt's Avatar
    Nova Scotia
    Hi, I just got my '01 gp gt about a couple months ago and love it!
    When I first start the car up and start moving I hear a kind of grinding noise which I assume is the abs, I had a cavalier that did the same thing. I didn't think much about it, lately it is like the abs has been coming on when I hit the brakes on dry pavement, none of the wheels are sliding and its the same noise as when I first start the car up. The abs light has never come on in the car, though I was letting it warm up the other day before work for a few min, when I came out and got in the car the low trac light was on, I put it in gear and it went off.
    From what I've read this could be a bad sensor and would have to change the whole hub for the wheel? How do I tell which one is bad? I was thinking of taking the fuse out....I'm not a big fan of it anyway but will I loose my tcs too?
    -Ryan.
  2. #2 Re: ABS problem
    SE Level Member Skeeve's Avatar
    carneyville FL
    was the tac dead as well? if it was thats a sign that the crank position sensor may be on its way out...
    99 Grand Prix GT
  3. #3 Re: ABS problem
    Nova Scotia
    Sorry, but I don't know what the tac is, I tried doing a search for it but nothing came up.
  4. #4 Re: ABS problem
    Jan 2009
    Tallahassee, FL
    Tachometer, the RPM gauge.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: ABS problem
    Nova Scotia
    Oh, yes the tach and all the gauges are working fine.
  6. #6 Re: ABS problem
    carneyville FL
    first, was it the low trac light or the trac off light? and was the tac working when the trac light was on? sorry i should have been more clear on that
    99 Grand Prix GT
  7. #7 Re: ABS problem
    Nova Scotia
    It was the low trac light, the tach was working with the low trac light on. The low trac light only comes on when the car is sitting idleing for a few minutes, I just put it in gear and start driving and it eventaully goes out, the same if one of my front wheels were spinning.
    It only seems to happen if I am driving slow, like in a parking lot, 10 km/hr. It is pretty annoying, it has done it 5 times tonight in a 3 minute span.
    Thanks for any help.
  8. #8 Re: ABS problem
    carneyville FL
    Just a shot in the dark, but could that be the speed control sensor?
    try pulling your two front tires of and cleaning the sensors maybe...
    (not too sure) ne1 else?
    99 Grand Prix GT
  9. #9 Re: ABS problem
    Nova Scotia
    I'm going to pull the front brakes off this weekend to see why they are squeeling, I'll clean up the sensors while I'm there and see if that makes any difference........anybody else have any ideas?
  1. ZZP PCM problem
    By davidl25 in forum General Tech Discussion
    Last Post: 09-05-2009, 10:28 AM
  2. HID problem
    By joshbarker in forum Visual/Body Modifications
    Last Post: 06-09-2009, 01:26 AM
  3. Gas Problem
    By flynn in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-07-2009, 10:27 PM
  4. Replies: 6
    Last Post: 02-07-2009, 01:16 AM
  5. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
