Thread: 2000 GT wheel bearing question
Results 1 to 14 of 14
  1. #1 2000 GT wheel bearing question
    Jan 2009
    Michigan
    I found wheel bearings on am-autoparts.com for about 50 bucks. Does this seem a little too cheap or should I go ahead and buy them.
  2. #2 Re: 2000 GT wheel bearing question
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    only way it should be that cheap if it was from a junkyard.
    Out side of a stocker only other brand i would use would be a timken
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: 2000 GT wheel bearing question
    Jan 2009
    Michigan
    1997 - 2001 Pontiac Grand Prix Front Wheel Hub Bearing Assembly
    Availability: In Stock, Ships Within 1 Business Day
    AM Autoparts Price: $53.30
    FREE
    2000 Pontiac Grand Prix Front Wheel Hubs - AM Autoparts
  4. #4 Re: 2000 GT wheel bearing question
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    The price should be more around $75 (no less) to about $100....
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  5. #5 Re: 2000 GT wheel bearing question
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  6. #6 Re: 2000 GT wheel bearing question
    Apr 2008
    Marion, Iowa
    Yeah, $60 if you get it now, last one left, 30 day warranty... If you are OK with that, and only need one, grab it. It will cost about $7 for shipping too, but not a bad price I guess, but could be a Chinese part which I've seen write up about how bad they are. A phone call to RockAuto would yield that answer hopefully. Or grab one locally that isn't Chinese made for about $8 more. It is up to you. I know some people (I used to be this way, so I completely understand) look at lowest bottom dollar. I also know that there are a lot of kids and students here where every penny counts, so I am not going to fault anyone for trying to save a buck.
    Just give them a call and see if this "last one" wholesale one is made in China. If so, skip it, if not, then the choice is up to you.
  7. #7 Re: 2000 GT wheel bearing question
    Waynesboro, PA
    Quote Originally Posted by nickbuol View Post
    Exactly. For the price, just get the whole assembly from somewhere you can cash in on the warranty if needed.
  8. #8 Re: 2000 GT wheel bearing question
    Jan 2009
    Michigan
    So the group consensus is that I shouldn't mess with the bearing from AM autoparts. I'll prolly pick up the $90 one at autozone.
  9. #9 Re: 2000 GT wheel bearing question
    Nov 2009
    Waco, Tx
    My car just recently started swerving really easy when i get to about 20mph. Its almost as if the steering just turn EXTREMELY easy and sensitive. I am unable to drive it over 20 or its pretty dangerous. I have driven it in an empty parking lot and it handles perfect when driving and turning (around 15mph). I also don't hear any grinding noise. I have heard a tick sounding noise from the driver side wheel. But the noise barely ever does it. I am 100% positive its not the tire pressure. If anyone has any advice it would help a lot. Thanks
  10. #10 Re: 2000 GT wheel bearing question
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Outer tie-rod going bad?
  11. #11 Re: 2000 GT wheel bearing question
    Nov 2009
    Waco, Tx
    is there a way i can check and see if that is whats causing it?
  12. #12 Re: 2000 GT wheel bearing question
    Jul 2008
    Livonia MI.
    Yea jack the car up n wiggle the tire side to side then top n bottom,
    that will tell u what is bad, (lower ball joint or outer tie rod)
  13. #13 Re: 2000 GT wheel bearing question
    Wooster, Ohio
    make sure on the bearing no matter what the brand, lifetime warranty, timkin is getting more foreign made everyday but just be sure its lifetime on these or don't waste your money
  14. #14 Re: 2000 GT wheel bearing question
    Donating Users ARFF22's Avatar
    NEW YORK
    Pay the few extra dollars for the good ones. I cheaped out and ended up re-doing the whole job again with the good ones. This is a perfect example of you get what you pay for.
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  3. ZZP Wheel Bearing - Any good?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2009, 03:31 PM
  4. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
  5. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
