Thread: *Clunking Noise From Front Left*
Results 1 to 13 of 13
  1. #1 *Clunking Noise From Front Left*
    WI
    Hello,
    I have a 2004 Grand Prix GT and here's my dilemma... I have this clunking noise that's coming from the front left of my car. It happens when: I put the car in reverse, put the car in drive, stop hard and then go, and turn the steering wheel and give it some gas in reverse. The clunking noise does not happen every single time, but most of the time. My mechanics have replaced the front left & right tie rods, front left & right wheel bearings, and the intermediate steering shaft. But, the clunking noise has not gone away! I joined this in hopes that anyone of you guys may know what the problem/solution is. It is really bugging the hell out of me!!!
  2. #2 Re: *Clunking Noise From Front Left*
    SE Level Member Dropped GP GT's Avatar
    Dec 2008
    Wyoming, MI
    i would look into either the ball joint or the cv joints.
  3. #3 Re: *Clunking Noise From Front Left*
    SE Level Member lorenzojay's Avatar
    Roseville Mi
    look at motor mounts as well.
  4. #4 Re: *Clunking Noise From Front Left*
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    Quote Originally Posted by Dropped GP GT View Post
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  5. #5 Re: *Clunking Noise From Front Left*
    SE Level Member copterdoctor's Avatar
    Bloomington IL
    How do the ends of the sway bar look? a Broken or split end sway bar will cause the clunking noise. I've seen it a lot on stock sway bars.
    If that's not the case, I would point to your Ball Joints. Especially if they are the originals on a car with that many miles and age. (I know, mine has 213,xxx miles on it so I have no room to talk about advanced age on a car)
    +249,000 miles and counting
    2000GTP: 3.4" pulley, 1.8RR, Full SLP Exhaust, ZZP PCM, CAI, GMPP kit, Eibach/AGX struts, W-body control arms, C6 brakes, HID projector headlights, 180*, AL104, 18x8 Verde Protocol wheels, TEP trans 3.29 gearing,
  6. #6 Re: *Clunking Noise From Front Left*
    HUDSON
    I had similar problem with my car, I did the upper dogbone bushing mod trick and it made all the clunck, bangs, and rattles dissapear. It it totaly quite when putting into any gear, and going over bumps, and when comming to a stop and then hitting the gas.
  7. #7 Re: *Clunking Noise From Front Left*
    SE Level Member Space Dynamics's Avatar
    Beltano Orbital Station
    I got the same thing. Only happens once per drive, and not every time. My 89' 525i did the same thing too.
  8. #8 Re: *Clunking Noise From Front Left*
    GT Level Member flash527's Avatar
    Indianapolis, IN
    mine does this too! the first time it happened all i could think of was that sounds expensive. is this something you can ignore without any significant repercussions?
    04 GTP - FOTB, Intense PCM, 180* Thermo, SLP Headers, 3.4" ZZP Modular Pulley, Moroso Race Wires, 104 Plugs, TEP trans: 3.29's, Thrasher shift kit. Soon to come: 13 inch dual piston brakes, rims and tires, wideband tune by PRJ.
  9. #9 Re: *Clunking Noise From Front Left*
    Bloomington IL
    Quote Originally Posted by flash527 View Post
    I don't think anyone could answer that. If you ignore something, and it turns out to be a ball joint or tie rod that's about to let go..... Then it could make sure you stop ignoring it.
    Suspension components starting to fail, usually destroy neighboring components and become a lot more expensive then they need to be when you start ignoring things you shouldn't
  10. #10 Re: *Clunking Noise From Front Left*
    Roseville Mi
    I found my clunking problem and it only cost 10 bucks. Sway bar link kit was all I needed, both were rusted through whew glad it was just that, now she handles mutch better.
  11. #11 Re: *Clunking Noise From Front Left*
    WI
    Well, I picked my car today from the shop. I have been outta town for a few weeks so the shop had alot of time to take a look at my car. They told me that they narrowed it down to either the front left ball joint or the front left lower control arm. I have a full bumper to bumper warranty, but it does not cover clunks and squeaks...go figure. The warranty is good till 100,000 miles so hopefully something goes wrong before then. My car currently has a little over 82,000 miles on it.
  12. #12 Re: *Clunking Noise From Front Left*
    WI
    Quote Originally Posted by QUICKSILVER462 View Post
    How do you do this mod trick? Is this something I can do in my garage?
  13. #13 Re: *Clunking Noise From Front Left*
    HUDSON
    Give this a try.
    Instead of using an easyout, I just reinstalled the bolt and nut to gain traction to turn the rubber.
    Ontario Quebec Club Grand Prix :: Engine Mount Stiffening Mod
    Dean
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. Front Left Turn Signal
    By upmm019 in forum General Tech Discussion
    Last Post: 09-05-2009, 07:04 AM
  3. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  4. clunking noise when i go over unlevel ground
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 07:16 PM
  5. Loud Clunking coming from rear left
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2008, 10:16 PM
