Thread: ABS Brakes.... Worth it?
Results 1 to 8 of 8
  1. #1 ABS Brakes.... Worth it?
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I'm wondering if anyone here thinks like me, first of all
    after hitting railroad tracks or a bump I cant get my car to stop because the abs kick in (basically delays the brakes completely, then pulses)
    And I'm from eastern Canada. Snow + abs = not good. When I brake going downhill in the snow nothing happens I just slide, I try to pump my brakes but does nothing.
    I think ABS is made for people that can't drive and have never heard of pumping brakes if they lock.
    Traction control on the other hand )) love it in the winter.
    any comments? have any of you bypassed it?
  2. #2 Re: ABS Brakes.... Worth it?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    to bypass you can pull the fuse
  3. #3 Re: ABS Brakes.... Worth it?
    SE Level Member evan14's Avatar
    South Carolina
    yeah i agree with him just pull the fuse
    green97 grand prix gt.............WE ARE ANTI HAHAHA
  4. #4 Re: ABS Brakes.... Worth it?
    Moncton N.B.
    will it show on your center display everytime you start your car that your abs is out?
  5. #5 Re: ABS Brakes.... Worth it?
    SE Level Member CenterionX's Avatar
    Frankfort
    My 2 cents
    Disabling the system will fix your current problem. But I would consider fixing them when you have the extra cash. You ability to stop "safely" will be diminished. ABS was installed because they stop a vehical faster and alow you more control during that stop. When tires lock up they melt, hence the the long dark black skid line. When they melt its like stoping on water or oil. Plus it is next to imposible to control the car in the situation.
    Like I said thats my two cents. Hope it helps.
  6. #6 Re: ABS Brakes.... Worth it?
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Quote Originally Posted by CenterionX View Post
    My 2 cents
    Close, ABS was not designed to make you stop faster, the design is to help you control your vehicle during a panic stop by not locking the brakes up. ABS has been proven to actually increase stopping distances (less effective) BUT that's against a professional driver that has the control to get max braking without locking up the wheel...which most of us cannot do. So, for the general population, ABS is a wonderful thing, especially being able to turn during a panic stop because the wheels did not lock up (skid), which is what it was designed for. When driving an ABS equipped vehicle, you are not supposed to pump the brakes as it'll actually make the ABS not function as it should, which would create longer stopping distances. If you activate ABS, you will feel the pedal vibrate against your foot, that's normal, and lets you know the ABS is working.
    Hope that helps.
    Jesse
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  7. #7 Re: ABS Brakes.... Worth it?
    Frankfort
    Quote Originally Posted by 03GTPLE View Post
    Hope that helps.
    Jesse
    The braking distance is only longer on gravel, sand and deep snow, ABS tends to increase braking distances. Other then that ABS is beats traditional bakes hands down. Please see the links below.
    You are right though ABS was originally researched to help with handling, IE "Traction Control". And oh what a difference it makes!!! Well I'm out again. Hope this helps you.
    Cent
    Anti-lock braking system - Wikipedia, the free encyclopedia
    ABS Frequently Asked Questions
    Keep Your (Braking) Distance: More Than Just Slowing Down
  8. #8 Re: ABS Brakes.... Worth it?
    SE Level Member vsl67's Avatar
    Australia
    Quote Originally Posted by Lionel View Post
    what is the rest of your braking system like ? New pads? rotors? tyres? etc If everything is up to scratch its unsual to have problems but if want to disable it pull out the relay and it should revert back to a standard braking system that what its designed to do if the system fails
  1. JET MAF worth it????
    By jimgimli in forum 5.3L V8 (LS4)
    Last Post: 06-13-2009, 07:43 PM
  2. Worth it or not
    By robahr24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-27-2008, 01:45 PM
  3. is it really worth it?
    By 99prixgt in forum PCM Tuning
    Last Post: 08-09-2008, 12:38 PM
  4. What do you think it's worth?
    Last Post: 03-22-2008, 05:23 PM
