View Poll Results: Which ones?
Voters
7. You may not vote on this poll
  • TDC Cross-drilled/slotted stock replacements for $150
    0 0%
  • ZZP 12" upgrade, new equip, plain rotor for $250
    7 100.00%
Thread: Brake options
Results 1 to 12 of 12
Threaded View
  1. #1 Brake options
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Hey guys, wondering what your opinions are on brakes...and ONLY these two options. Please do NOT tell me to get f-body brakes b/c they are not one of the options I'm presenting.
    It's time for me to get brakes, and I need new rotors as one of mine was trashed (pad wore down to metal). I am on a very tight budget, but want to get something decent since I need new rotors..and part store rotors are a ripoff.
    From TDC Racing, I can get stock replacment rotors with cross-drilling/slotting and Hawk pads for roughly $150 http://www.topdeadcenterracing.com/P....aspx?CatId=20
    The other option I'm considering is
    ZZP 12" upgrade with the single piston caliper. This comes with new plain rotors, calipers, bolts, bushings, and powerstop pads for about $250. http://www.zzperformance.com/grand_p...=576&catid=138
    I thought the stock brakes were pretty good stock, which is why I'm considering the TDC route, as it'd be the same cost as parts store stuff, but would help on resale...as a potential buyer wouldn't care if the brakes were bigger, but looked cool ...
    If it were you, would you spend the extra $100 for all new equipment and a larger, plain rotor? I do NOT have enough money to get f-body calipers. (or cross-drilled/slotted 12" rotors)
    Thanks for your opinions.
    Jesse
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  1. TB options
    By 4drgt in forum 04+ Specifics
    Last Post: 09-12-2009, 03:14 PM
  2. HO Alternator options?
    By Luda in forum Audio, Security & Visual Electronics
    Last Post: 09-03-2009, 02:59 PM
  3. Rotor Options
    By sirschuster in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2009, 07:22 AM
  4. Any exhaust options for '91 GT 3.1L?
    By 66custom in forum General Tech Discussion
    Last Post: 05-13-2009, 03:18 PM
  5. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
