on my 05 gtp whenever the car sits for a while and then I back up and then go forward the traction control message comes up on the info center and it acts like the abs system is activating. any ideas
any codes or other messeges when this happens? Does it correct itself immediately? more info please.......
There weren't any codes that came up and I decided to go to a local repair shop and they connected the ABS scanner up and found the Right Front speed sensor has a bad connector. They quoted me for a new wheel hub and jumper cable (as the old one had been cut and I spliced it back together) for $475 total.
$60.00 Cable
$160.00 Wheel Speed Sensor Hub
$187.00 Labor for installation.
I was thinking of installing it myself, any opinion?
