Thread: Coil spring boosters
Results 1 to 7 of 7
  1. #1 Coil spring boosters
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Hey everyone
    I just put a type r box in my trunk and noticed quite a drop in the rear suspension. The damn box must weigh close to 100 pounds! It makes the car look kinda dumb with the huge wheel gap only on the fronts. I was thinking on picking up some of those rubber spring boosters for the rear to level it out somewhat for now until I decide what to do. I would like to lower the car but don't want to spend all the money right now on new struts, and from what I have read a camber kit and mount spacers. (correct me if I'm wrong). Has anyone ever used the spacers and if so, how did they work?
    Any input would be appreciated.
    Thanks!
  2. #2 Re: Coil spring boosters
    TDCRacing
    Guest
    Use soem GTO spring blockers. They use them from the factory to prevent spring sag and to help the cars from scrubbing when going in and out of the trailers during shipment.
  3. #3 Re: Coil spring boosters
    Jan 1970
    Maquoketa, Iowa
    Could also use Olds Intrigue rear springs. They are a bigger spring and will solve the squatting issue in the back that you see in stock suspensions
  4. #4 Re: Coil spring boosters
    May 2008
    Ontario
    Quote Originally Posted by TDCRacing View Post
    Are these on the GTO model cars or is GTO the maker of the spring blockers?
  5. #5 Re: Coil spring boosters
    May 2008
    Ontario
    Quote Originally Posted by FoSHO99 View Post
    Thanks for the info, I am hoping to avoid replacing springs for the time being, but that's good info to know.
  6. #6 Re: Coil spring boosters
    TDCRacing
    Guest
    The GTO spring blockers come off of the GTO cars. I just saw some for sale on nepec I think.
  7. #7 Re: Coil spring boosters
    May 2008
    Ontario
    Too bad we don't have GTO's in Canada (I wold have one if they did) to make finding some easier. They sell them at auto parts stores around here which I imaging are pretty simmilair.
  1. Coil Packs
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 12:16 PM
  2. coil brackets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 02:53 PM
