Thread: F body brake swap
Results 1 to 20 of 28
  1. #1 F body brake swap
    GT Level Member pski920's Avatar
    Oct 2008
    Endicott NY
    I was at my local parts pull yard and was working on removing parts from a 98GTP (same as mine only a sedan). It just so happens a 3.4L 4th gen Firebird was right next to it with all the brakes and suspension on it. It looked like the rotors were the same size as the GTP, are they the same? I thought they were supposed to be approx. 1" bigger. Is this swap only beneficial from a V8 model Firebird/Camaro? I looked in past threads, but couldn't find anything to ans. my question. Thanks.
  2. #2 Re: F body brake swap
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    The only F-body brakes that are compatible are from the 98-02 F-body's.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: F body brake swap
    Oct 2008
    Endicott NY
    so would a V6 model be the same as what i have on my 98GTP or do i need to take it off of a V8 model. they look like the same diameter rotors on the V6 as the ones that are on my 98 GTP.
  4. #4 Re: F body brake swap
    Banned
    Wichita Falls, Texas
    Has to come off of a V8.
  5. #5 Re: F body brake swap
    Jul 2008
    Dekalb, IL
    From what I've heard some of the V6's have the dual piston calipers too.
  6. #6 Re: F body brake swap
    Oct 2008
    Endicott NY
    Well must be this one I saw didn't have that set up. It looked similar to the one on the GP. I'll have to look around some more then. What exactly do I need off the V8 donor car? Rotors, Calipers, Caliper brackets, etc??
  7. #7 Re: F body brake swap
    Banned
    Rotors, calipers, brackets, thats it.
  8. #8 Re: F body brake swap
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Street Wolf View Post
    False. All 98+ F-Bodies have the "upgrade" from brakes.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  9. #9 Re: F body brake swap
    Oct 2008
    Endicott NY
    Even the V6 models? I'll have to check the year of that car again. I think the later modeled F bodies had the 3.8 in them? This one had a 3.4L.
  10. #10 Re: F body brake swap
    Jul 2008
    Dekalb, IL
    Correct the F-body's you can get the right calipers from will either have an LS1 or a 3.8 in them.
  11. #11 Re: F body brake swap
    Oct 2008
    Endicott NY
    thanks. i'll look out for one.
  12. #12 Re: F body brake swap
    GT Level Member 98daytona500's Avatar
    Nov 2008
    st louis
    ya all the fbody i get the setup from are 98+ and most have been v6
    i have a set sitting right here i just got the other day
    but u will have to either drill and tap the brackets or get the spacers..
    14MM bushing (this is used so you can simply re-use the bolts off the Caliper brackets and not tap them)
    http://www.mcmaster.com
    Part# 6679K16 Desc: Metric Steel-Backed PTFE-Coated Brnz Bearing for 12 mm Shaft Diameter, 15 mm Length Price
    99 buick regal gsx..headerz, 3" motor back exhaust , lowered on B&G springs, transgo shift kit, solid offset front motor mounts, 3.2 mps, fuel pump rewire, zzp h/l cam, tinted headlights and tails, 5% tint all around zzp s2 alt booster, alt rewire, al103, jmb, ported blower, machined lim
  13. #13 Re: F body brake swap
    Waynesboro, PA
    Quote Originally Posted by 98daytona500 View Post
    McMaster-Carr
    Please do not promote the use of those god-forsaken sleeves!
  14. #14 Re: F body brake swap
    Oct 2008
    Endicott NY
    what are the bushings used for? couldn't i just use the caliper bolts that come with the Fbody? will the brake hoses transfer right over?
  15. #15 Re: F body brake swap
    Waynesboro, PA
    Quote Originally Posted by pski920 View Post
    The bushings are to re-use the F-Body bolts. They are 12mm, whereas stock for the Grand Prix is 14mm, so folks use the sleeves to compensate for the 2mm. Please do not do that. Just get the F-Body bracket tapped to the 14mm size and use the stock Grand Prix bolts.
  16. #16 Re: F body brake swap
    Oct 2008
    Endicott NY
    oh definately, i would just tap the bolt holes. i have all the tools to do that and have done it before. i'd want to use the larger bolts (stronger) anyway. is that common practice for most people to use the bushing? seems easy enough to tap the holes.
  17. #17 Re: F body brake swap
    Dec 2008
    Toronto
    Anyone know if 2004 GTO (yes, gto) front duel piston calipers will fit on my 00' GTP if I go with a 12' rotor? I called my GM dealership and ZZPerformance today but they were unsure if the GTP will accept the GTO rotors. They look like the same duel piston calipers from the F-body cars. Thanks
  18. #18 Re: F body brake swap
    GTP Level Member Scimmia's Avatar
    QCA, IA
    nope, won't fit, the bracket is too different.
    2001 Buick Regal LS - Almost Stock
  19. #19 Re: F body brake swap
    Bastard Reptile's Avatar
    Kansas City, MO
    Just a word of advice for ya.....Don't expect a GM Dealership to really help you like this. They don't want to be held liable for any damage caused by selling you different parts that aren't designed to fit your vehicle. Sounds dumb to some people, but we can't just come out and say that we will sell you F-Body brakes for your Grand Prix.
  20. #20 Re: F body brake swap
    Wichita, KS
    Quote Originally Posted by JoshMcMadMac View Post
    Amen.
    Seen too many calipers come loose, a mounting bolt falls out, (usually the top bolt) the caliper flips up, and grinds on the inside of the rim.
    I remember seeing one rim that was damn near completely sawed in half, but that was the 12" factory brake upgrade, and a bolt didn't get tight. That came loose on a driving course, and he didn't know what that noise was for a few laps, and I think when he lost air pressure was when he finally stopped. The caliper sawing through the inside of the rim was what made him loose all his air pressure.
    ~F~
  1. E-Brake Pwn
    By Freebeer187 in forum General Tech Discussion
    Last Post: 10-28-2009, 03:54 PM
  2. KVR big brake kit
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2008, 07:00 PM
  3. Major loss to the G-body/W-body community
    By Sabrewings in forum Off Topic Discussion
    Last Post: 05-21-2008, 03:47 PM
  4. Throttle Body swap
    By Berger in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2008, 08:35 PM
  5. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
