Thread: Front rotor problem
Results 1 to 5 of 5
  1. #1 Front rotor problem
    Aug 2008
    KCMO
    so i need to take my front rotors off to be turn and put new pads on but for some reason i cant get my rotors off i have tried beating on them with a BFH and they still wont budge. Any one have any idea of what i can do to get these biatches off?
  2. #2 Re: Front rotor problem
    Jul 2008
    Tampa, FL
    have you used a clamp on the pistons to release the pressure?
  3. #3 Re: Front rotor problem
    Aug 2008
    KCMO
    problem solved. PLEASE DELETE THREAD
  4. #4 Re: Front rotor problem
    MA
    Quote Originally Posted by carl06GT View Post
    Please elaborate, others may find your solution helpful
  5. #5 Re: Front rotor problem
    Aug 2008
    KCMO
    i just ended up spray some penetrating fluid on them and let it soak in for a bit and then just beat the crap out of the back of them. i only advise this if you need to buy new rotors cuz they will not be able to be turned.
  1. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  2. rotor thickness
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2009, 12:10 PM
  3. hot wheel/rotor
    By yourTVlies in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2009, 09:59 AM
  4. where to buy 12" rotor
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2008, 02:02 AM
  5. gtp s/c rotor swap HELP
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2008, 01:33 PM
